How much does it usually cost for a 383 stroker kit?
Old Jul 31, 2002 | 10:46 AM
vhgjk123's Avatar
Post How much does it usually cost for a 383 stroker kit?
just curious
2000 SS Camaro
free mods, K&N Air Filter, Air Temp Module
13.45 @105.48mph on Bald Tires
Old Jul 31, 2002 | 12:29 PM
supersp0rt's Avatar
Post
well, SLP has one on their website for $10,500. 530hp and about 510tq.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
Old Jul 31, 2002 | 12:31 PM
one wicked element's Avatar
Post
I think LS1's go to 382. I could be wrong though.....
Old Jul 31, 2002 | 01:47 PM
Trevor98ramair's Avatar
Cool
The LS1 rotating assembly uses the stock bore with a 4" stroke. The complete rotating assembly from Lunati (forged pistons, rods, and crankshaft) sells for $3,995. If you want a complete package installed with our heads/cam package, etc., then you're looking at somewhere in the ballpark of $11,000. That price is what it would cost out the door.
Feel free to give me a call if I can help you out.
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Old Jul 31, 2002 | 03:33 PM
stockLT1's Avatar
Thumbs up
mine ran 11,000 for the shortblock...but I'm sure you can get a cast rotating assembly cheaper.
Later,
-Scooba
'93 Z/28 M6 3.73's_6point cage_orange with yellow pearl_RK sport GFX_SS hood_RK sport hi rise wing_clear corners_billet grille_ported heads/intake_5 angle perf. valve job_97'LT4 383 by SELF RACING_CALLIES stealth crank_OLIVER six inch rods_J.E.forged dished pistons_10:1 compression
OLIVER splayed mains_custom grind cc306_LINE BORED_BALANCED AND BLUEPRINTED_FASTCHIPS custom chip and ED Wright DYNO tune_EGR bypass_home made SFC's_home made short throw_home made LCA's_home made CAI
Eibach Pro kit_ET Streets_Hooker ceramicoated LT's W/true duals and "H" pipe_Taylor Spriro wires_Autolite 104's_Aeromotive adjustable FPR_30# injectors,58mm TB, 1.6 comp pro magnum RR's
NX wet 250 shot
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
globalprojeff
Dec 6, 2014 04:18 PM
