Ive got BOOST but NO inlet tubing
Old Jul 11, 2003 | 07:59 PM
JohnGuc's Avatar
My tuner did a dyno run today without the inlet tubing in place and he got 8 to 10lbs boost at about 3000rpm before he shut it down.
So now Ive found the problem but I dont have an intake tube.
Does anyone make this for the Corvette or anyone have any ideas how they fabbed one??
John
Old Jul 11, 2003 | 09:21 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
sounds like you had the stock piece and it was collopasing! you will need to probabyl get a custom one made.. I assume the shop that did the install could handle that np.
Old Jul 12, 2003 | 01:06 AM
JohnGuc's Avatar
They should eventually
But if I can come up with something before they do it would be faster
Ive been without the car for long enough.
Old Jul 12, 2003 | 12:58 PM
texlurch's Avatar
All you need is some mandrel bent pipe in the correct diameter, a sawzall and a welder! Nothing to it!
Just use your stock inlet pipe as a pattern, and get to work!
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
