2 ohm, or 4 ohm
slayer6x6
07-11-2003, 05:46 PM
My buddy has a 97 trans am with the 8 speaker system. I remember hearing that some of the newer trans am's had 2 ohm speakers. The rear 6 1/2 is blown, so can i replace with a 4 ohm aftermarket speaker?
bighurt1
07-11-2003, 09:58 PM
You won't be able to. I'm sure somebody can explaing better than I could. :(
PaulN64
07-11-2003, 10:47 PM
if he has the Bose system, then yeah, they are 2ohms. You can replace it w/ a 4ohm speaker but it just won't be as loud
slayer6x6
07-12-2003, 06:50 PM
Do you know of any aftermarket companys that make a 2 ohm speaker, or is he stuck using a 4 ohm and getting crappy sound quality. Do you have any idea of how much a 2 ohm speaker would cost from a dealer?
bighurt1
07-12-2003, 09:13 PM
It's going to sound like crap. Trust me! I replaced my middle set of speakers after they were blown with some set of Pioneers and they sounded like crap.
It's best to go back to stock or change your whole system completely.
PaulN64
07-12-2003, 11:31 PM
:thumb:
kerberos
07-17-2003, 12:38 PM
if you have a 4 ohm tweeter and a 4 ohm 6,5" you can connect them paralell and the circuit will have (1/ 4 + 1 / 4 = 1/0,5 1/0,5=2) 2 ohms
Ted J
07-17-2003, 12:44 PM
Doesn't work that way when a cross-over is added into the mix if the cross-overs are designed correctly, passive that is. The amp will still see a 4 ohm load in the situation you describe above.
