DanTheIROCMan
07-11-2003, 10:43 AM
I've been having this problem ever since I had the fuel pump replaced from this shop I used to go to that really butchered my car. I've taken it back several times but eventually gave up and just delt with it. But since I found this board, I thought maybe someone here could help.
Here's the deal. After driving the car around for awhile, especially when stuck in stop and go traffic, tremendous pressure starts building up in the gas tank. I know this because you can hear/feel the gas tank expand abruptly and it usually scares the hell out of me. Then, if you park the car and turn it off, you can actually hear the pressure being released slowly through the air canister in the engine compartment. That goes on for at least an hour or so. You can really smell the gas fumes as well. Then, when the car finally cools down later on, you can hear the gas tank contract and it always sets off the alarm. It's like a loud "bang".
My theory is that somehow the fuel is getting way to hot in the tank and causing excessive fumes which in turn causes pressure to continuously build. I know that some pressure is normal, but this is totally excessive.
Could they have put the wrong fuel pump in and it's putting out too much pressure which is causing too much heated fuel to return from the engine? They have already checked the regulator and said it was fine. Also, the car seems to run really rich now and smells horrible, although strangly enough, it did pass smog not too long ago.
Any help would be appreciated.
