Lights, Radio, Alarm, ALL WONT WORK!!Help
99TransAmWS6
07-10-2003, 04:39 PM
My dome interior lights, my headlights, my parking lights, my radio..none of them will turn on..so i figured ah blew the fuse. Its not the fuse! The fuse is fine..i have no idea what it is..the fuse isnt blown what else could it be..i have no idea where to even start looking...help me!
Rice Killer87
07-10-2003, 11:38 PM
are u sure the fuse isnt blown? have u tested it w/ a test light,if u ground the test light and touch both little metal "testers" on the back of the fuse while its still in the fuse block,it should light up when u touch both sides...if it doesnt,change the fuse.
if its not that,id say its a ground problem somewhere or its not gettin any power at all.
Don 79 TA
07-11-2003, 06:29 AM
My other half is having the same exact issue with the headlights, iterior light, door locks.
just stoped on her. gonna have to look at it in the shop, it's driving me crazy.
99TransAmWS6
07-11-2003, 04:07 PM
the fuse is fine..i dont have a test light...have to see if i can find one..any other ideas??
Slow91z
07-11-2003, 05:48 PM
Check any fusable links inder the hood.
kevin 2.8
07-11-2003, 10:59 PM
check for loose wires/couplers under the dash?
dealership said my signals didnt work because of 'missing wire to bcm connector'
bastards
99TransAmWS6
07-12-2003, 12:03 PM
Still no luck here guys...i cant drive the damn car if i dont have lights...bad enough without the radio..im lost :confused:
Shaun 90 Iroc
07-12-2003, 01:15 PM
Make sure all the fuses are the correct amp as well. Try to see how those things not working are related as far as the wires and fuses to them. If you don't have a tester.. stick in a new fuse and see if it works. Look for loose or fried wires.. have fun!
99TransAmWS6
07-13-2003, 12:06 PM
fusiable link down by the starter was shredded. Dunno how..took us a couple hrs to find a 2$ fix.
Slow91z
07-14-2003, 03:08 PM
I'm so good I don't know what to do with myself.
