can't get Belkin F5U103 to work
Dan95TA
07-09-2003, 11:26 PM
I have a amk cable and i tested it out on my desktop and it passed fine. I have a newer sony vaio laptop without a serial port, so I bought the Belkin F5U103 and still am having problems getting it to work. When I run the aldl test the lights on the belkin flash but it still fails the test. I am using com4 haven't had much luck setting it to another com. When I run the aldl test the far left two green lights flash and when I try to test it in hyperterminal the lights flash when I type but I get some crazy characters on the screen...I'm not sure I setup hyperterminal right though.
Can anyone help me get this thing going, the laptop also has a amd athalon processor if that makes a difference.
Dan
Highlander
07-10-2003, 12:37 AM
im having more or less the same problem..can you send me the aldltest program? the tts link is not working.. please send it to highlander@caribe.net
THanks
Dan95TA
07-10-2003, 12:44 PM
just sent it, let me know if you get yours working.
Dan
Highlander
07-10-2003, 04:41 PM
I had a problem with my serial card... THanks
Hotwire
07-11-2003, 12:01 AM
could you send me the aldl test program to jncbowne@bellsouth.net
Are you guys running winxp? I just got a brand new dell inspiron 1100 specifically for working on my lt1, and can't get it to work, and can't download the program. So far my hyperterminal works, but i cant test my aldl just yet.
I tried a manhattan adapter, didn't work, so now i have a belkin f5u409. i can get the computer to communicate w/ the pcm, but it's nothing but garbage, it won't "link up" w/ the pcm although there is data going back and forth, watching comm log while trying to connect.
ps, i have the communication log if any serial tekkies read this and am curious, i would appreciate any help.
TriPinTaZ
07-11-2003, 12:57 AM
i think it has to be on COM1
LT4ultraZ
07-11-2003, 05:52 PM
I am having the some of the same problems as hotwire.I have the DELL inspiron 1100, free scan will work but when i try to down load the program from my car with PMC prog it will start and go for about 8% then it will say that it has lost conection and lock up. troy
Highlander
07-11-2003, 06:53 PM
I have the f5u09 from belkin and it works with efilive...
Rufus
07-11-2003, 11:05 PM
TTS reorganized their website, you need to reset your old links starting from their home page http://www.ttspowersystems.com/ and navigate to the diagnostic software page.
Gary
