xkatodude 07-09-2003, 10:42 AM Its not the motor itself, its the exhaust. Like when you first start out in gear i get this rattling sound. I have a feeling when the motor turns a little, it throws the I-pipe up against the floorpan or frame somewhere, and it makes this chitter sound. It does it in first and in reverse, sometimes it'll do it if it shifts hard into second. Does anyone else's car do this? And if yours has done it, or did do it how did you fix it, or do you know for sure where its tapping the floorpan?
Its a 96 3.8.
I do have dual exhaust on it, but it was doing this before back when it had the regular single factory exhaust, so i believe its the I-pipe..
shortdog273 07-09-2003, 11:32 AM It could be the I pipe vibrating up against that support brace that goes across it near the cat. I just got a pair of pliers and bent the support brace down on each side. No more vibrating. :)
xkatodude 07-09-2003, 11:41 AM i'll look into that, thanks.
I'm also wondering if it could be the x-brace, i dont' know how close the pipe comes to it. (its a convertible, so it has the x-brace). I wish there was a way i could see where its vibrating, but since it only does it when the car is moving, its kinda hard to look up under the passenger side, LoL...
Satellite98 07-09-2003, 10:31 PM Do I?!!
I've got TWO, at the moment. A light rattle coming from the heatshield and another (louder) coming further towards the front because of a loose clamp.
Its my 3rd or 4th rattle, including when the antenna was loose. My car must be special.
I did get a sig out of it, though. :)
Satellite98 07-09-2003, 10:33 PM BTW, mine is idle and very low RPMs (around 1600 or so). Last time I had it, it would rattle much further up the rpm band. Makes it seem like I"m driving a beater
Temporary fix: Tighten everything up.
Permanent fix: Trade it in for a Mustang ;) :p
jetman624 07-10-2003, 06:42 AM My car is curently making the same noise, last time this happened it was the cat falling apart. I put on a new one and it was fine. Mine is getting progressivly worse. It strated being only when i first gave it gas in 1st or reverse, and now it just makes its's randomly. So I'm assuming its the cat again.
xkatodude 07-10-2003, 10:27 AM in other words the best solution for me, is when i go to get the stupid muffler place that put my exhaust on crooked to get them to bend one of the pipes to make it straight, i should get them to deal with it. It did it before the exhaust was changed over to dual, but not as much, it has gotten progressivly more noticible.
kingman109 07-13-2003, 12:19 AM ha i just started having same prob....looks like its a heat shield near rear of car by muffler...i bent tip of it down and it stopped for a week...bottomed out and started again...gonna have to fix again i guess
sick94 07-17-2003, 01:34 AM Me too, course it didn't start happening until after i cut the cats off. After i cut the cats off and went to a muffler shop and had them weld a piece of pipe where the cat was, and my duals also. There was no rattling for a while, but now there is a rattling sound all the time. Its starts after the car warms up, exhaust wise, and sounds like i'm driving a clunker. I've talked to some ppl about it but they all say it is a brace or something loose. i've been under the car and can't find anything loose when it's cold. The only think i can think off is that when the exhaust heats up it expandes and started touching something. This happens in all gears and at almost all rpm ranges. If anyone has any ideas lemme know, thanx, AJ
xkatodude 07-17-2003, 09:24 AM I crawled all up under the car yesterday, and i everywhere the pipes are a good 2 to 3 inches away from everything.. so i can't figure out what it could be touching. right in the middle of the car, there is a heat shield that touches the pipe, but it looks like its attached to the pipe.. and its like way up under there where you can't reach from the side of the car.. I'll go take some pictures of it in a minute, and then edit this post..
Edit:
I took some pictures, but they all came out really dark, except for the one of the muffler, but i know thats now the problem..
http://www.coldfuzion.nu/coldfuzion/exhaust007.jpg
Oh! you can see the heatshield i was talking about in that pictures.. its all the way at the edge going back toward the motor.
kingman109 07-17-2003, 05:53 PM my problem is that heatshield for the gas tank by the muffler...if i bend the corner down it seems to fix it....it kinda vibrates with my exhuast for some reason...its real strange...and it only happens at low RPMS....
NBAballer40 07-18-2003, 01:23 PM i have a 96 3.8 liter 5-speed and i had that same prob. the rattle was almost beating a hole in the bottom of my center console. i got under the car and my transmission bracket was off on one side and i put another screw in it and it stopped my prob totally.
kingman109 07-18-2003, 03:55 PM not anything to do with tranny on me...ive had bad tranny mount and thats completely different sound...this one is coming from the vibrating heatshield for some reason...mehh...soon as it stops raining ill have to fix it somehow
xkatodude 07-18-2003, 04:25 PM I think i'm just going to lie to the muffler shop. Since i have to take it up there to have them heat up the drivers side outlet on my dual exhaust and bend it so that its straight (because they put it on crooked) i'm going to say that it never rattled before they put my new exhaust on.. And make them track it down and fix it..
JaysZ 07-18-2003, 05:09 PM Originally posted by kingman109
my problem is that heatshield for the gas tank by the muffler...if i bend the corner down it seems to fix it....it kinda vibrates with my exhuast for some reason...its real strange...and it only happens at low RPMS.... Yep, me too. I think it's a resonant frequency thing. I can do a quick fix (bend) but it slowly comes back.
xkatodude 07-18-2003, 09:15 PM if you are bending the heat shield down, and the muffler is under the heat shield, what is tapping on what.. cuz in my mind this isn't making much sense...
JaysZ 07-19-2003, 10:34 AM Originally posted by xkatodude
if you are bending the heat shield down, and the muffler is under the heat shield, what is tapping on what.. cuz in my mind this isn't making much sense... Mine is above the I pipe- right before it connects to the muffler. There is probably nothing touching. The vibration of the muffler may be inducing a vibration into the thin head shield material. I simply have to grab it an it stops (or bend it into a different position).
sick94 07-19-2003, 09:43 PM yeah this rattling thing doesn't make much sense to me either, ya know it can really drive you crazy. every time i get into my car it drives me insane :mad: AJ
kingman109 07-20-2003, 04:30 PM same prob here...nothing is touching the metal...but it vibrates and makes the noise...if u touch it it stops...by bending it it stiffens it for a while so it cant vibrate like before.....wierd;)
1KillerV6 07-22-2003, 03:37 PM Mine has a high pitch noise too but its bcuz of the jack and doughnut tire that is loose. :p
silicuda 07-22-2003, 07:28 PM on mine the heat shield was giving me problems, when id rev high it would rezonate like a mofo... so i had to screw the heat shield back into place properly with some slef tappin screws..
