what are the chances of a blown headgasket if you don't have mixed oil/coolant?
Old Jul 7, 2003 | 04:18 PM
mineralwater's Avatar
I've read on this board that it is possible to blow a head gasket, where only combustion gasses escape into the lifter valley.
I have excessive crankcase pressure, and very thin wisps of smoke puffing out of the oil fill cap. I thought it was my piston rings at first, but I only have 95k on my engine and I am lightly modded. Nothing major. My oil pressure is completely normal, and my car doesn't overheat or anything.
Reasons I think I have a blown head gasket:
1) Spitting/chuffing sound from inside engine. Sounds kind of like a cross between an exhaust leak and lifter tick. However, I have no exhaust leaks, I just changed out my bad lifters to good ones, and relashed all rocker arms.
2) Sweet, pungent exhaust smell. Its also very acrid and makes your eyes water. I do have a catalytic converter, so I'm sure this isn't normal.
3) Thin white steam, but not very much, coming from exhaust. the steam is very moist and kind of sticky.
4) If I hold my hand over the tailpipes, it feels like its raining. Water droplets shoot out of the exhaust tailpipes even at idle.
5) Car is *very* slow and down on power, makes hissing when engine is under load. Sounds kind of like a couple loose spark plugs.
6) About 4 months ago, my car overheated and went almost to the red. The temp needle stayed at the 3/4 mark for about 5 minutes.
7) About 1 month ago, I saw a small streak of milky oil under the driver's side valve cover. I wiped it off, and since then, it hasn't come back.
I haven't had milky oil, no air bubbles in my coolant, nothing.. is it still possible I have a blown head gasket?
I am going to borrow a friend's compression tester, but even if I'm losing compression, I probably won't be sure if its rings or head gaskets.. how would I be able to tell?
Well, thanks for reading.
Old Jul 7, 2003 | 04:23 PM
kmook's Avatar
Advanced Tech Moderator
Quite a few of those make it sounds like a blown head gasket.
Old Jul 7, 2003 | 04:41 PM
thanks, Ken. (this is kyung btw)
which ones make it sound like a blown head gasket? some have told me #2, #3 and #4 are normal for a cammed/headered car.. hmm.
Old Jul 7, 2003 | 05:00 PM
kmook's Avatar
I know
WTF? I dont know what cars they have but water out the exhaust isnt normal on a cammed/headed car...
I was going off of 2/3/4.
Old Jul 7, 2003 | 05:07 PM
Great! Believe it or not, a blown head gasket is good news to me. It sure as hell is better than a re-ring, since I almost have the heads off already anyway.
Well, I may be the first person to say this on the board, but.. "Gee, I hope I have a blown head gasket!".
Thanks, ken.
Old Jul 7, 2003 | 05:12 PM
kmook's Avatar
Well i hope you have a blown head gasket too
CamaroRob97's Avatar
I've been through a head gasket job before so let me make one suggestion...PORT & POLISH!!! Oh and a 3 angle valve job!!!!!! u'll regret it if u don't ! i dodn't do it to mine and really really wish i had!
Old Jul 8, 2003 | 04:58 PM
Dr.Mudge's Avatar
If it is just the heads/gaskets, its a relatively easy job
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
captcorvette
Mar 7, 2015 12:37 PM
warmeck
Mar 1, 2015 08:47 PM
