94SLUG
07-07-2003, 12:37 PM
part# db4201-12 which means 42inches on 12 rib. I would use a dreyco but need a part # and vender. Where do you all buy your blower belts from?
Thanks Bill
Thanks Bill
Pulling my hair out trying to find gates blower belt! Where to buy?94SLUG 07-07-2003, 12:37 PM part# db4201-12 which means 42inches on 12 rib. I would use a dreyco but need a part # and vender. Where do you all buy your blower belts from? Thanks Bill Sparkz28 07-07-2003, 01:31 PM I get mine from NAPA.... 94 NO TOP Z 07-07-2003, 03:19 PM Semi-truck part places usually have them too. Usuall the number of ribs and the length is all you need. A lot of them the last 3 numbers is the length in inches.... xxxxxx400 would be 40.0" long. 97TA-WS6-Con 07-07-2003, 06:16 PM I found that Gates only makes that size for ATI. I bought a 41 inch from NAPA and it would not fit. I called Gates directly and they said they made the 42 inch but that they only sold that belt to ATI. ATI charges $75 for a 42 inch belt and NAPA charges about $37 for a 41 inch. What are you gonna do? :shrug: If anyone knows a cheaper way to buy a 42 inch belt....... 94SLUG 07-07-2003, 06:29 PM Originally posted by 97TA-WS6-Con I found that Gates only makes that size for ATI. I bought a 41 inch from NAPA and it would not fit. I called Gates directly and they said they made the 42 inch but that they only sold that belt to ATI. ATI charges $75 for a 42 inch belt and NAPA charges about $37 for a 41 inch. What are you gonna do? :shrug: If anyone knows a cheaper way to buy a 42 inch belt....... Smaller pully and more boost :p j/k . LOL Thats the problem I'm having. I put a 41 on before, but it was not fun and takes 2 poeple. So I had to pay 75 from ati as well. Anyone use Dreyco belts, I only ask because thats what my brother uses(Novi blower). Anyone know gates phone number? There based out of the UK and I cant find a state side number. yenkoz28 07-08-2003, 01:50 PM I'd just get a dayco polycog belt. They should have one in your size. I bought a goodyear gatorback poly belt from summit a year or so ago. All I did was give them the gates part number and they sent the correct belt to me. IDOXLR8 07-08-2003, 03:34 PM IMO I would just run two 6-rib gatorback belts. 97TA-WS6-Con 08-14-2003, 01:08 AM Would this work? i might try it. I keep chewing up belts and these Goodyear ones would be cheaper I assume. ATMINF 08-14-2003, 01:13 AM Are you sure your NAPA does not have it? I am in the Military and have been in many different places and all the NAPA's that I went to had my belt. If it was not in stock they ordered it. I am talking about when I was at FT Stewart GA(by Savannah), FT Benning GA, about 1.5 hours South of Atlanta, and Victorville CA. 96 WS6 08-14-2003, 06:01 PM carquest ATI426 08-14-2003, 06:36 PM I have got mine at A-line Auto parts. They always seem to have what no one else does. Brad StephenF04 08-14-2003, 11:50 PM My buddy runs a Vortech and gets his Gates belts from NAPA. zturbo 08-14-2003, 11:57 PM IMO I would just run two 6-rib gatorback belts. Didn't Kmook run 2 6 rib belts and run into problems with it as well as some others?? I would get the single myself. IF you find a good parts counter guy he will find the belt you are after. Years back when i worked at Carquest in the warehouse they even had cogged belts like for blowers :| big ole mofo's Steven kmook 08-16-2003, 04:46 AM Originally posted by zturbo Didn't Kmook run 2 6 rib belts and run into problems with it as well as some others?? Steven Yes, 2 belts = Teh Suckage. Well then again the tension pulley being miss aligned may have had something to do with it :think: :irk: steve10358 08-16-2003, 08:06 AM Industrial truck shops and hutchins (in WNY) carry them. :) | ||
