Hobbs Switch?
Wild1
07-05-2003, 01:53 PM
Newbie to N2O, what is a Hobbs Switch? I can understand how it would work with a turbo or S/C but I can't figure out how to use it with N2O. Any benefit? Is it something like a window switch? Or a Fuel Pressure Safety Switch?
slow
07-05-2003, 03:08 PM
the fpss is a hobbs switch.
Ryan.
Z28ROC
07-05-2003, 04:29 PM
Fuel pressure safety switch. It will shut the n2o off, if the fuel pressure drops below the set psi.
Wild1
07-05-2003, 04:44 PM
So is it adjustable or is it set? If I'm running a separate tank (low psi) for racing fuel (3 gallons) up front where the battery used to be, then how would I adjust the Hobbs/fpss?
Hawk
07-07-2003, 04:55 PM
it's adjustable, turn the screw on top. Hook it up to a air compressor to get the psi u want.
Wild1
07-07-2003, 07:24 PM
Air Compressor... great idea.
