the nitrous works whoas
moostadon
07-05-2003, 05:24 AM
i just installed the nitrous works wet system and i have some poping when it is activated and some surging.the car feels like it falls on its face then it will go .i just checked the a.f.r. and it read
11:7:1 when its juicin .i was told i have to regap my plugs to about .035 from the stock .060 i also removed the hypertech engine tuning before i ran it .every time i check the bottle it has 900 pounds. i am flustered please help
RUFFIDLNZ
07-05-2003, 10:46 PM
Did you regap your plugs? Also did you check the system before you ran it? If you didnt unhook the lines and have someone, or yourself hold the lines in a coffee can or something and then have someone operate the system and make sure you are getting both the juice and the fuel. Also are you sure you are running the right jets and what size shot are you running?
moostadon
07-06-2003, 04:39 AM
well i just regaped the plugs to .035 and turned up the fuel pressure 44 psi i found it at 36psi before. ran great but bottle only had 600 psi.but i just remembered that i forgot to put the vacvuum line back on my regulator opps!!
TMDZ28
07-06-2003, 12:05 PM
where's the vacum line man?? i want to double check that one also...thanks
