making a Fbody handle like a Z06?
Old Jul 11, 2002 | 09:20 AM
maddboost's Avatar
Question making a Fbody handle like a Z06?
I was wondering if anybody knows if it would be possible to get a 98+ Fbody to handle almost as good or even better than a Z06. Now of course their is the weight difference but what can you do about that, and the T-Tops that come on almost every friggin Z28. But I read in "Car and Driver" the Z06 pulled a 0.96 in the skidpad, could you forseable put those same parts or similar parts on a Fbody to make it handle just as well or is the suspension set up too different?
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
Old Jul 11, 2002 | 12:37 PM
99Z28RS's Avatar
Post
Its been said that with Bilstien shocks, eibach springs and some BFGoodrich G-Force T/A KDW(S) that the camaro will pull .9 or somewhere close to that, so my guess is that if you added all that with a strut tower brace, and sub-frame connectors you could probably achieve that
99 Z28RS
SLP LoudMouth
SLP Air Temp Module
MTI Carbon Fiber Air Lid/K&N
EGR Mod,FRA Mod
Old Jul 13, 2002 | 07:50 PM
danz28123's Avatar
Post
I believe the z06 has independent rear suspension, so it would be hard to match the feel of that. You could probably get it to pull .96g though.
Old Jul 14, 2002 | 10:49 AM
Cricket92RS's Avatar
Wink
It will take a WHOLE lot of things to get a fourth gen close to Corvette handling, and even then you'd probably be just close. That's what the car was designed around, to make it a street legal but race ready machine. They are perfectly balanced with their weight front to back (50/50), and they are made to haul @ss turning in any direction while doing it. The Camaro's however are built to burn the back rubber off and hang the @ss out while doing it. The ole live axel makes for some fun at the auto-x events!
1992 Camaro RS 25th Aniversary Edition, White, 3.1L MPFI V6, A4, catback exhaust with Flowmaster 80 Series, K&N with modded airbox, Eibach Pro-Kit lowering springs.
1999 Camaro SS #4224, Navy Blue Metallic, M6, Pro 5.0 shifter, whisper lid, and ported maf ends.
Old Jul 14, 2002 | 04:41 PM
Capn Pete's Avatar
Wink
How to make a Z28 handle like a Z06???
Basically: extend the wheelbase by 3", widen the stance by 2", lose an extra 300lbs, and replace the live-axle rear and less aggressive front suspension for a tuned, 4-wheel independent system. That should just about do it!
OR: buy a Z06!!
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - No Pics yet.
meissen
Jun 1, 2015 07:59 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
ChrisFrez
Dec 7, 2014 06:01 PM
