bottle heater questions.....
TMDZ28
07-04-2003, 08:46 PM
in my bottle heater, there are two wires coming out. which of these two wires that i have to connect to the thermostat and to the power??? anyone can help me out here??? thanks
sniffin94
07-05-2003, 01:16 AM
it doesn't matter which wire you run to the power. The other needs to ground
sideways_Into_3rd
07-05-2003, 06:49 AM
neither one goes to thermostat .. u need to run a relay with ur heater .. the relay signal wire goes thru the thermostat
TMDZ28
07-05-2003, 12:03 PM
what relay?? i dont have any relay, i only have two wire. that's it. :confused: :confused: :confused: :confused: :confused:
Wild1
07-05-2003, 01:39 PM
Does anyone have a wiring diagram? Perhaps this will better explain it. A pic is worth a thousand words... one of Pamela Anderson is worth millions... ;)
robss96dcm
07-05-2003, 09:39 PM
did you look here
http://www.nitrousexpress.com/installation/bottleheaterinstall.pdf
Wild1
07-06-2003, 01:00 AM
Works for me... :)
TMDZ28
07-06-2003, 11:55 AM
Originally posted by robss96dcm
did you look here
thanks rob, thanks wild1
