500 rwhp or bust - Today at Rezniks
Draco
07-04-2003, 12:59 PM
Hey guys,
I am going to be hitting the dyno rollers at 330pm today at Rezniks. I am running a 9 PSI non-intercooled setup, and hoping for 450-500 rwhp.
Just giving you guys a heads up in case you want to check it out.
I will NOT be running the Nitrous on top of the blower because I just don't have the fuel pump capacity at this time.
ollie-99
07-04-2003, 01:04 PM
nice good to hear!!!
good luck on the rollers
:cool:
oh btw are u selling ur borla? shoot me a PM
Tw!tchb!tch
07-04-2003, 01:10 PM
:eek: Im going to try to stop in for sure !! :bow:
JD30thZ28
07-04-2003, 01:22 PM
I wish I could be there :thumb: Good Luck :bow:
My guess is 508rwhp :cool:
LuCiFeR97Z28
07-04-2003, 01:28 PM
Good luck Craig! I say 478 RWHP :).
StreamlineZ28
07-04-2003, 01:38 PM
good luck! my guess is 496hp
what do we win if it is right ;)
JD30thZ28
07-04-2003, 01:43 PM
I was off by one HP on Payam's car and I got nothing :cry:
sideways_Into_3rd
07-04-2003, 02:13 PM
should be in the 500 rwhp range give or take .. but im still kickin your azz down the track and down the road craig :D
talos
07-04-2003, 02:59 PM
where is Rezniks i would love to check this shat out.
Draco
07-04-2003, 04:58 PM
The address is 1655 Broadway 120
Basically from North Van take the United Blvd exit right before the Port Mann Bridge, and follow the Mary Hill Bypass until you get to Broadway. Turn left and drive about 1/2km
ollie-99
07-04-2003, 05:04 PM
haha i remmeber getting lost thats all:rolleyes:
sideways_Into_3rd
07-04-2003, 08:16 PM
well i guess bust it was after all :p
just buggin ya .. but if u start listening to peoples advice u'll get up there no problem ;) (ignition box and IC)
heres the video (download it cuz i cant keep it on my webspace for long .. need my disk space for assignments :p)
http://www.sfu.ca/~pkavousi/115-1504_MVI.AVI
hey since we have identical HP #s me and u should be head to head .. lets find out :D
NiteRider
07-04-2003, 08:34 PM
So what are the numbers? :confused:
Camaro ChriSS
07-04-2003, 08:37 PM
I wish I heard about this earlier. I was up around Reznick's around that time...
I look forward to seeing your numbers. Good luck.
Draco
07-04-2003, 08:40 PM
OK here are the results:
first pull (let off early at 5000 IAT climbed to about 70 degrees C):
peak TQ 463 at 5000
peak HP 442 at 5000
This would have been the vbest run for power if we had gone to 6k.... oh well.
2nd pull (let off early at 5700 IAT climbed to 85 degrees C)
peak TQ 460 @ 4800
peak HP 470 @ 5700
3rd pull (let off at 6000, IAT climbed to 103 degrees C!!!!!)
peak TQ 458 @ 4800
peak HP 467 @ 5500
A/F ratios were 12.2 all the way to the end on all of the runs so the tune is looking pretty good as-is.
As you can see my IAT's are getting way too hot and that is bringing down my power... Gotta get an intercooler, even with 9 lbs of boost! My TQ should be peaking at around 5500 rpm, not 4800.
So, it looks like I am sitting at 470 rwhp for now, and I am happy with this on a nice conservative (rich) tune. Let's see what the track says!
CoryM
07-04-2003, 08:54 PM
Cool craig. Glad to see things are working out for you. Nothing exploded and caught fire :D . Good #s man. Forget the intercooler, just spray some nice, cold nitrous in there ;) . What lb injectors you have now and what do you think you need?
CoryM
Draco
07-04-2003, 09:01 PM
I am running 50lb injectors. They were hitting approx 85% duty cycle, so they are about right in terms of size.
I am probably gunna hook the Nitrous up again and run a 75 shot or so. My fuel pressure was fine up to 6k rpm, and I will hook up the FP safety switch to be safe. Hopefully the nitrous will help cool the intake charge a little bit also ;).
THis is a wet kit so the injector duty cycle will not be affected.
bunker
07-04-2003, 10:23 PM
Congrats man, those are pretty ok numbers, get an IC in there :)
Camaro ChriSS
07-04-2003, 10:49 PM
You have a real nice set up Craig. I am truly jealous. :bow:
Congrats on everything being so smooth. You've obviously done a great job (and those that helped you too, if there was help).
Intercooler. I agree.
KA0S
07-05-2003, 12:29 AM
Awesome numbers man:thumb:
raene
07-05-2003, 01:00 AM
What is it with you domestic guys and not running an IC!! Sheesh! Some import guys even run ICs without being boosted! ;)
Seriously though, nice #s! Even a small shot of nitrous will help out majorly... however I've heard more than one story of a blower exploding from nitrous being plumbed through it. Just be careful! :bow:
Zedzag
07-05-2003, 01:27 AM
Damn I'm jealous of all you 400+ rwhp guys. Nice numbers Craig..all that work is paying off. Get some tires:p
Tw!tchb!tch
07-05-2003, 01:52 AM
:mad: ah **** I wanted to see you pull . I had to go get some primer on a couple jobs for tomorow so they could dry overnight and just got back :rolleyes: GAY!!! Those are some ****ING WICKED NUMBERS MAN !!!!:bow: Just think how much faster u will be at ax with a full 4X too much power :p
Tw!tchb!tch
07-05-2003, 01:56 AM
Some import guys run guages without anything hooked up too :irk: :Owned:
Draco
07-05-2003, 02:13 AM
Thanks guys! I really couldn't have made it this far without the help and encouragement of the denizens of this board. I hope I can return the favor sometime, so ask for my help if you need it!
Matt, Armen and I worked on a little cooling spray just now (approx a 100 shot) and went for a rip. All I can say is I wish I had this hooked up for the dyno runs :D
Raene, no worries about the blower not liking the nitrous - we are spraying after the blower so it should be fine.
raene
07-05-2003, 04:38 AM
LOL!! :D Nothing beats having a naturally aspirated car with a boost gauge! All the looks without any of the bad gas mileage or annoying "psssh" sounds, what more could any F&F lover want?!?
bunker
07-05-2003, 04:12 PM
Hey Draco had that going on for about a month or two :)
LuCiFeR97Z28
07-05-2003, 04:21 PM
Congrats Craig, nice to see everything is coming together nicely. By the way, I was closest guessing the numbers :D.
JD30thZ28
07-07-2003, 12:59 PM
I have had that going for 2 years now, lol :lol: I should install one of the blower kits I buy ;)
Craig get some stickies and let your track times prove it :thumb: Your car moves and you can definately tell there is more power to be found :cool: :bow:
ollie-99
07-08-2003, 11:19 AM
Congrats on the #'s
im scared to see what it would be @ w/ the n20
