BennyBoy
07-03-2003, 07:33 PM
I will be installing some RK Sport headers into my car within the next week or two, and I was wondering whether I should get the 3/4" Stage 8 bolts or the 1" bolts. I shouldn't need anything other than bolts, WD40 (to remove bolts), and some gaskets... right? I have the stuff to block off and remove the AIR and EGR.
Thanks guys :)
Draco
07-03-2003, 07:42 PM
I tried using Stage 8 bolts on my RK Sports.
Some of them would NOT fit due to the size of the bolt head (primaries were in the way).
You might be better off saving money and just running ARP header bolts.
BennyBoy
07-04-2003, 11:29 AM
Hmmm... that's good to know. Is there anything I can do to prevent them backing out? Can I use lock washers?
Draco
07-04-2003, 12:07 PM
I personally havent had a problem with my bolts backing out. I just tightened them down after 50km and they havent come loose.
Not sure if lock washers would help that much
JD30thZ28
07-04-2003, 01:30 PM
You won't have any problems with them backing out, just get some 3/8 ARP header bolts, after a few days of driving re-tighten everything and you will be fine, I have used these on the three sets of Headers I have had with no problems :thumb:
BennyBoy
07-04-2003, 01:46 PM
OK, one last question to harass you guys with. :)
3/4 inch or 1 inch length?
Edit: I think the 1 inch are the ones to get. Someone correct me if I am wrong... lol :p
JD30thZ28
07-04-2003, 01:57 PM
Don't remember that one :think: Although I can check that for you tonight. Installing FLP's On Perry's Camaro. :)
BennyBoy
07-04-2003, 02:54 PM
OK... I don't think ARP makes a 1 inch bolt... lol. I am going to get ARP part # 400-1101.
http://www.arp-bolts.com/media/pdf_files/header_bt.pdf
JD30thZ28
07-04-2003, 03:29 PM
3/4 length is right :thumb:
BennyBoy
07-04-2003, 04:38 PM
Thanks. Good luck with the FLP's. :)
spo/z mike
07-04-2003, 06:53 PM
:p :p :p lets see some pic's of perry's ride :)
