Maro98
07-02-2003, 11:31 PM
My clutch went out on my V6 98 Camaro and im about to buy a new one and I plan on buying a aftermarket performnce clutch will it make any diffrence at all or should I go OEM? Tanks in advance for your advice.
Clutch questionMaro98 07-02-2003, 11:31 PM My clutch went out on my V6 98 Camaro and im about to buy a new one and I plan on buying a aftermarket performnce clutch will it make any diffrence at all or should I go OEM? Tanks in advance for your advice. silicuda 07-03-2003, 01:33 AM get centerforce dual friction.. do not waste your time on OEM OEM sucks, centerforce DF is the way to go! payce fbird95 07-03-2003, 02:06 AM Like stated above, the OEM is a waste of time unless you got a hook up on it for a cheap price. Its not that its a bad clutch and that your 6 cyl needs a super duty clutch, its more like what it will run you to get one from GM will be not worth it. just make sure not to go to agreesive, because it can tear up your rear over time if its too extreme. Maro98 07-06-2003, 01:32 AM aight thanks for your help Ill look at the centerforce dual friction clutch. Ohh and I was wondering will it make much of a diffrence in acceleration? | ||
