purge work yesterday, but not today
TMDZ28
07-02-2003, 10:30 PM
what the hell is going on?? my purge works fine yesterday, now no more. do you guys think this is the switch?? i bought a new switch have not have the change to install it yet, i use a used switch that my friend gave me.....i'm just a little pissed off right now....:mad: :mad: :mad: :mad:
RacinLT1
07-02-2003, 10:42 PM
it could be the switch,could be a ground,bad power source,purge solenoid coulda died.
Way too many options,start with the simple,switch and make sure it has power,then see what happens.
It's not the end of the world,just a purge solenoid,no reason to go flipping out. Just relax,replace the switch and go from there.
TMDZ28
07-02-2003, 11:34 PM
hmmm, ok. but the purge solenoids cost money, and i spent $90 to get my window switch installed today. damn, i guess, i'm just tired. i only had total of 7 hours of sleep in two days :( :mad:
HungryT/A
07-03-2003, 06:25 AM
First, calm down, get a sleep..etc. :)
Then check your ground. Where have you grounded it?
I had it grounded under the PCM bolts first, but it gave me problems, so I relocated it to the negative battery pole. No problems so far!
Good luck,
TMDZ28
07-03-2003, 01:37 PM
i put all my switch and ground wires for purge button and arming switch to a bolt right behind the (i dunno what is called, but it's under the cd player). i have to open everything again, and check everything again. oh well. i bought a new button for it. hopefully it's the button. thanks guys.
TMDZ28
07-03-2003, 05:14 PM
this really pisses me off now. i tried to take all the switches off, but i could not. this purge does not work right after a shop install my window switch. do you think they might have done something to it???
TMDZ28
07-03-2003, 06:34 PM
okay i called the shop again, and they said that i need to ground the purge by itself. is this true??
RacinLT1
07-03-2003, 06:48 PM
seeing how we really dont know how your car is wired,it could very well be true.
good luck
N2OpwrdTA
07-03-2003, 09:01 PM
Dont know which kit you got...but on my zex kit, my purge kit has its own power and ground to the solonoid. So, you should have a power and ground wire for the purge solonoid....At least, thats how i wired mine. My window switch does not have anything to do with my purge. I can purge nitrous without my nitrous being on cause my purge 12v is aways hot, not switched. Idea, maybe your purge is wired into your nitrous arming 12v so that would mean the window switch is not letting it get power unless your in your window of operation. If thats the case, just get you 12v for the purge from the battery. Doesnt drain anything if its wired right.
Maybe..try setting your window switch "on" setting to like 600rpm...then turn on your nitrous(if you have to for your purge) and see if it purges. If so, the above mentioned is your problem.
TMDZ28
07-04-2003, 12:38 AM
i'll try calling the shop again, i'll tell them to take care of it, even though it will cost me a little bit of money. i want to purge so muchhhhh
RacinLT1
07-04-2003, 08:51 AM
get in there and chase the wires out,see how it is was wired,and see if you can get it working. Like N20 said,it might be wired through the window switch.
Much more enjoyment knowing you fixed it yourself and didnt have to rely on a shop to get it right,IMHO.
TMDZ28
07-04-2003, 12:03 PM
true, true.......i think i'll just try to fix this stupid problem myself:)
N2OpwrdTA
07-04-2003, 12:29 PM
Yeah....just trace the wires and fix it yourself. Obviously, the shop doesn't know what their doing anyhow. I put a writeup of how to wire up a harlan window switch to my zex kit a while ago. Search for it, maybe itll help if they wired it in using a relay(they should have).
edit...heres the link for ya in case it helps. http://web.camaross.com/forums/showthread.php?s=&threadid=134020
TMDZ28
07-04-2003, 12:55 PM
thanks dude
