Turbo charger help
kaoticcamaross
07-02-2003, 04:59 PM
I have a 95 z28 with just a few mods. I wanted to know if theres a supercharger you can put on a 95 z28 without having to replace to many stock parts such as drive shaft and so on an still beable to get into the 11's.
96TurboTA
07-02-2003, 05:49 PM
Your post says "Turbocharger help", but your asking about superchargers, which is it?
kaoticcamaross
07-02-2003, 06:48 PM
Sorry It's been a long day. I meant to say turbo.
SMOKNZ
07-02-2003, 10:54 PM
As long as you don't run slicks the stock parts will last you a while. I have a friend that ran the stock rear and driveshaft even with slicks and an auto with no problems. If your a stick shift car avoid slicks and big clutch dumps, the big torque down low likes to bend and twist things up a bit.
kaoticcamaross
07-03-2003, 10:18 AM
Ok so I could buy a turbo and all i would need is the turbo set up and the intercooler. My stock gears, driveshaft, suspension, and lt1 will be ok. Just to make sure I'm getting this right. Also how much psi would i need to keep it around.
SMOKNZ
07-03-2003, 10:17 PM
I ran mine with the stock rear and driveshaft for a year or so before i went to the 9" rearend. It wasn't really needed but was something i felt i would eventually need. That was on the stock motor too. If you keep it tuned right it can live a while. The conscensus seems to be no more than 6 psi non-intercooled, and 8 psi intercooled. But even then guys break their pistons, so if your stepping up to forced induction always be prepared for the inevitable.
