shutting off the bottle!!?
Ataririder
07-02-2003, 01:23 AM
Ok,
After I'm done with the track, I turned off the bottle and I still had 600lbs of pressure in my line. How do you get rid of it? Should I just loosen the hose to get it out? I know that all that pressure is not good for the solenoid. Please help.
Loadre
07-02-2003, 01:24 AM
Choice 1 - Buy Purge kit.
Choice 2 - Put rag around house while slowly loosening it.
My84Z
07-02-2003, 08:21 AM
step 3 shut off bottle and hit the go juice
john97z28
07-02-2003, 11:17 AM
That is one of the main reasons I bought a purge kit.
FirehawkNS
07-02-2003, 04:56 PM
Thats what I do. Just a quick WOT hit with the switch on, and bottle closed!!!!
Deadcarny
07-02-2003, 06:04 PM
hopefully you guys are doing this (purging through the nozzle)either while driving at WOT or after the car has been shut off and is not going to be drivin for a while. N2O at idle is very bad.
FirehawkNS
07-02-2003, 06:35 PM
i don't know about everybody else, but yea, never shoot into the car at idle, or off and crank up. I do it while driving the car. flip the switch, push her to the floor, at 3,000 rpm's it kicks in for a second to purge. Then flip the switch off, and go about your buisness!!!
Z28ROC
07-05-2003, 04:36 PM
Before I had a purge. I'd just crack the nut at the bottle, to purge the line.
