How do i know if rotors are warped?
Old Jul 1, 2003 | 07:40 AM
SNEAKY NEIL's Avatar
I have a feeling at least one of my brake rotors is warped due to the fact that the car shudders under braking and this increases when the brake temperature increases. So how I tell if a rotor is warped or not? Thanks.
Old Jul 1, 2003 | 07:45 AM
That is a good indication.
Old Jul 1, 2003 | 07:53 AM
..................but how do I know which one(s) it is by looking at it or by doing some sort of test? I'd rather not just replace all of them.
Old Jul 1, 2003 | 07:57 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
you generally just have to worry about the front two... they don't need to be replaced, just resurfaced... a shop can do it relativly cheap...
Old Jul 1, 2003 | 07:59 AM
Normally it is the front ones. You would always want to have them machined in pairs, so the chance that you will fix it by machining/replacing the fronts is very high. Probably the only way you can detect it, is to check the runout with a dial indicator.
Old Jul 1, 2003 | 08:31 AM
Mindgame's Avatar
That'd be the way to check.
A friend of mine was having the same problem. Checked it with a dial indicator and nothing out of the ordinary... a few thou runout. Yet the car had a real problem. Cleaned the rotors with an abrasive Hawk Blue pad and no more problems.
Not saying that your problem is not in fact a "warped" rotor, but it may be the same as we experienced.
Here's a link to the thread where more of this is discussed.
http://web.camaross.com/forums/showt...5&pagenumber=2
Good luck.
-Mindgame
Old Jul 1, 2003 | 10:00 AM
I think I will try that cleaning pad. Now that I think about it, what was said makes sense. The rotors look like they have some buildup on them.
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
