Powerdyne internal belt?
Maldo
06-30-2003, 01:04 PM
Hi guys what is the width of the internal Powerdyne belt? (in mm)
MislMan
06-30-2003, 06:52 PM
This is "old" data taken from the Mustang board at corral.net
Hope it helps!
Belts:
Gates Powergrip HTD 375 5M (Kevlar)
Standard 32-36mm 375 5M (Fiberglass)
Powerdyne rebuild
Belt info
IPS
7739 Tonja Ct.
Byron Center, MI 49315
Paypal accepted
E-mail Matt at ForcepowerEng@aol.com
Belt is $40.00 plus $6.00 shipping anywhere.
“Gates” Numbers on belt: 3755M also 421MC
Bearings
Lower 6202FCCB $59.20 for 2 in ceramic
Upper 6205 $16.00 for 2 in steel w/krytox grease
3 day UPS $14.45
$89.65 total for me
Paypal accepted
Forcepower - My number is 616-437-2296. Matt
Later ... Larry S.
Maldo
06-30-2003, 10:32 PM
[QUOTE]Originally posted by MislMan
[B]This is "old" data taken from the Mustang board at corral.net
Hope it helps!
Belts:
thanks but when i called gates they need the width of the belt in mm to order
Erik 94TransAm
07-01-2003, 09:10 AM
Stock width is 33mm, i don't know if gates has one, you may have to go 35mm wide.
Its 375mm long w/ a 5mm pitch. So, 375 x 35 x 5. Fiberglass belts are $11, kevlar are around $20 from local dealers.
Big bearing is a S205SS, small is S202SS. $15 and $10 respectivly from local dealers.
Maldo
07-01-2003, 11:16 AM
Cool thanks you very much for this info (this is a big help).
I will contact Gates to see if they can get a belt like this to me
Because i know they make one that is very similar then but i am not sure if it is 33mm wide
I think a gate makes up to 22 or 25 mm wide in this belt configuration.
Has any one tried this?
I know the other guy sells them but he only take paypal or check which take a long time I have a local Gates supply warehouse that can have the belt to me the next day.
Erik 94TransAm
07-01-2003, 01:35 PM
Depends who you're buying from.
tip87gt@aol.com sells a 35mm wide kevlar gates belt that he spray paints black so hopefully you won't figure out the size. I'd try and stay above 30mm for strength sake.
Maldo
07-01-2003, 01:40 PM
This Belt is from “Gates”:
I ordered it from a suppler over in my area.
If this works i will let you guys know. This would be nice becasue these belts are dirt cheap and i could get them for allot less then what most are selling it for.
