TravProcharged94Z
06-29-2003, 06:11 PM
A few months ago there was a link that showed the measurments and such for making a mount for the wheel well.
I did a search and could not find it anyone have a link to it? Its a 10lb bottle btw.
travis
Sunsceamer
06-29-2003, 08:54 PM
I dont have any pic but yes it will fit with 2 brackets and if you use only 1 I can fit a 15 pounder
stik6shift98
06-29-2003, 09:07 PM
yes thats where i have mine mounted....i used a plywood board as a base it looks good
maximumvelocity
06-29-2003, 10:34 PM
measurements anyone? I want to do the same thing, rest the bottle on a board.
kirschman
06-30-2003, 12:12 AM
http://gallery8926.fotopic.net/photo.php?o=1&id=550130 here mine, just used the supplied brackets that came with the NX kit. one more http://gallery8926.fotopic.net/photo.php?o=1&id=550129
TravProcharged94Z
06-30-2003, 12:28 AM
kirschman
Looks good i might try it that way.
The mount i was refering to was something someone had fabed up using some metal plates. It mounted to the spare tire bracket and then mounted across to the other side.
thanks for the help so far :)
Travis
TravProcharged94Z
06-30-2003, 12:34 AM
Found a link to one of the brackets. You can see it in the 1st and 2nd pics.
http://www.gafba.com/articles/article.asp?tid=4
Now a few weeks ago someone had some measurements and how to make this. Looks simple just like to get it right and the diagram would make it a lot easier.
Kirschman what part of KY you from?
thanks
Travis
kirschman
06-30-2003, 05:05 PM
hows it going Travis, I'm from Bardstown. Usually race at ohio valley(louisville) or Hardinsburg. I mounted the bottle directly to the wheel well. Put the tall bracket on bottom and the short one on top, exactly oppisite of how its supposed to be. I drain every bottle, so it gives me a good angle. Make sure u get the siphon tube in the right spot.
FirehawkNS
07-02-2003, 05:07 PM
Heres my 15lb bottle mounted in the spare tire well!!! Sorry don't remember the measurements, I just started fabbing the post to screw into the car to mount the bottle and next thing I knew it was done!!!
http://venomoussvt.com/pewterz28/images/nos_install2.jpg
http://venomoussvt.com/pewterz28/images/nos_install5.jpg
