help needed with intake sensor mod
Lord_Yeyo
06-28-2003, 02:37 AM
i heard that a mod can be performed on the intake system..apparently i have to buy some sort of resistor at radio shack...can anybody give more detail on this..what type of resistor should i buy..installation?(website?)...i have a 95 v6 3.4L has anybody done this mod with a similar vehicle..like a mentioned above which type would be best for my car..any help on this matter is greatly appreciated
1fastV6
06-28-2003, 03:15 PM
its a joke mod. especially on your vehicle. dont waste your time or money.
fbird95
06-29-2003, 02:08 AM
You can also relocate it with a longer wire to a colder air source, (Air Temperature sensor) to advance the timing. Like mentioned above its not worth it and most likely you gain Zero hp from it.
The only thing worse is that SLP sells a kit for this, and pretends it actually does something.
A better mod would be a fan switch, you can get one in for under 10 bucks.
Lord_Yeyo
06-29-2003, 03:53 AM
fna switch...ive heard of that..where can i get more info on a fan switch..is it something that anybody can install them selves..where would i go to buy one..autozone?
fbird95
06-30-2003, 01:27 AM
For you car you need wire, 16 gauge is what i used, and a switch. Single pull single throw. (SPST) All you need to do is to run a wire from the green (ground) on the fan, or even easier from the fuse panel under the hood, to one side of the switch, and run the other side of the switch to a ground. This is For OBD I cars. Also the key will need to be in the acc position to turn the fan on. OBD II cars require a few extra steps, like resistors. I mounted my switch next to the trunk relaese on the lower dash. If you do this, you will need to take notice to what is behind where you want to put the switch before drilling. Cost me about 2.99 for the switch i had the wire. The whole thing costs under ten bucks to do and took me about 20 minutes to install.
