How To Fix A Flaired Cam Dowl........????????
Old Jun 28, 2003 | 12:24 AM
jdvm95Z28's Avatar
Question How To Fix A Flaired Cam Dowl........????????
I just purchaced a Lt-1 to LT-4 conversion kit from Scoggin Dickey..... and when I logged onto their web site it stated that the dowl pin on the Hot Cam needed to be pushed in to .10 +/- .01...... Well I did as they advised and I flaired the dowl so it wont fit into the timing gear hole now..........How do you get a dowl out of a cam shaft.......If i can get it out then I can use the dowl from my stock cam to put into the new one.......
Old Jun 28, 2003 | 04:20 AM
anaik's Avatar
Take the flare off with a file.
Old Jun 28, 2003 | 06:41 AM
Don 97 SS's Avatar
I had to grind down the dowel on mine because it exceeded the max installed height of .620". I used a grinder and carefully removed the excess material (and resulting lip I created in the process) and then ensured that the O.D of the pin was no more than the max. of .250". One can remove the pin for this simple procedure, but it is unnecessary (assuming the cam is not already installed in the engine).
Garcia5
Jul 7, 2022 06:51 PM
rednekrocketeer
Apr 20, 2015 09:17 AM
armedtrigger
Feb 24, 2015 08:30 PM
squarehead
Nov 21, 2014 08:02 PM
MislMan
Jul 19, 2002 11:41 AM
