Njgunslinger
06-27-2003, 09:45 PM
for the rear, i want to stiffen the back end so it stops rubbing against my tires
What are some good adjustable shocksNjgunslinger 06-27-2003, 09:45 PM for the rear, i want to stiffen the back end so it stops rubbing against my tires chuck 06-28-2003, 10:09 AM Koni or Hal are really your choices. I have Koni's and really like them. But, I have to ask, where is it rubbing? And is there another way to stop it? Stiffening the shocks will reduce traction. You should be able to roll the fender lip and/or tweak the inside of the wheel well with a body hammer (just make sure the back seat is up). Njgunslinger 06-28-2003, 05:43 PM The lip of the fender keeps hitting the outer edge of the tire, so maybe rolling the fender will work, Im going to try that first. But I dont like the fact that the car bounces that much where the fender would rub the tire stik6shift98 06-28-2003, 06:33 PM comp engineering is what i would get..... Njgunslinger 06-28-2003, 11:49 PM comp engineering shocks? | ||
