Quick/Easy crank/timing queston
Old Jun 25, 2003 | 04:54 PM
95_RipperZ's Avatar
I turned the crank too far when I was pulling off th crank gear and cannotbring it back. So how many times forward do I need to rotate it around to get it back to the point it was at. I think it is 4 but not positive. The cam sprocket is fine and right where is should be. I need to realign the dots though. Thanks.
Old Jun 25, 2003 | 04:58 PM
I assume the chain is off. Just realign the dots and all is well.
Old Jun 25, 2003 | 05:11 PM
95_RipperZ's Avatar
ya, the chain is off. so just 1 time around until it is back at 12 o clock? So it doesnt need to be in sequence or nothing. My thought was b/c the crank sprocket is much smaller it required more turns to equal one turn of the larger. If ot, that makes it much easier b/c I am fightin compression.
I probably sound stupid but timing is a major thing and I dont want to mess it up. Thanks.
Old Jun 25, 2003 | 05:14 PM
kirschman's Avatar
Shoebox, got a ? for ya; Ok, our cars have keyless cranks right? Say u have the motor at no. 1 TDC,and u have a cloyes double roller. They have the 4 * advance and retard. U have the cam sprocket "dot" at 6'o clock. Now, how can it make a differance where u put the dot on the crank sprocket since its not keyed?? Seems like u could put it the "dot" anywhere on the crank, as long as its at no. 1 TDC, and that would put the cam at the recommended straight up. Correct me if i'm wrong, this was just bugging me when I put my cloyes in.
Old Jun 25, 2003 | 05:21 PM
Yes, the crank turns twice for every rotation of the cam. That means there are two times the crank is in the same position during a full sequence of the firing order.
The only thing you really need to know is to put the dots together.
Old Jun 25, 2003 | 05:23 PM
The hub is not keyed. The sprocket is. That is where the timing between the crank and cam must be maintained.
Old Jun 25, 2003 | 05:29 PM
kirschman's Avatar
So there is a key for the crank sprocket on the crank?? I cant remember when I put mine on I thought there was no key at all on the crank? Note to self; dont drink while trying to put a t/c on
Chet1185
May 12, 2013 10:48 AM
cargotec
Apr 27, 2013 01:06 PM
cargotec
Advanced Tech
Apr 27, 2013 12:46 PM
