96cam4ro
06-19-2003, 04:27 PM
I'm planning to get a set for $119 at JEGS without any emissions hookups. I also plan to get the Y-pipe for $99. Do these bolt right in or do they require some modifications? Its for a 91 TBI. Thanks.
Headman headers96cam4ro 06-19-2003, 04:27 PM I'm planning to get a set for $119 at JEGS without any emissions hookups. I also plan to get the Y-pipe for $99. Do these bolt right in or do they require some modifications? Its for a 91 TBI. Thanks. 96cam4ro 06-19-2003, 04:32 PM Oh yeah, do the stock plug wires work with these headers or do I need another type? Rice Killer87 06-19-2003, 06:25 PM i have some on my 87 350 TPI and they are great. mine bolted right in. i had to play w/ y-pipe some b/c it wasnt perfect but hell,nothing is. buy them! TheGreatJ 06-19-2003, 08:13 PM I got the coated Hedman shorties and absolutely LOVE them. You have to jack the driver's side of the motor up about 1.5" to get the driver's side header in, but other than that it's a very straightforward install. I chose to use wires with 90* boots and ran them under the headers....not sure if the stock style wires will work or not. I also had a custom Y-pipe built along with the 3" cat-free exhaust. 12Second3rdgen 06-20-2003, 03:59 AM The Y pipe should be fine for an L03 motor, but honestly that Y pipe sucks my ass, so if you ever go to a bigger motor down the road definately have another made. gun4hire 06-20-2003, 04:28 PM When I got mine, I found that it was not a direct bolt-in with the factory Y pipe since they used the 3-bolt collector flanges (not the 2-bolt factory style). They also did not line up where the factory y-pipe matches up. I intend to re-do mine at some point (longtubes?) we shall see once I get the $$$ VortecZ28 06-21-2003, 03:49 PM Originally posted by 12Second3rdgen The Y pipe should be fine for an L03 motor, but honestly that Y pipe sucks my ass, so if you ever go to a bigger motor down the road definately have another made. the only problem with the Heddman Y pipe is the pipe size, 2 1/2" if I remember right. | ||
