3M 39006
black97ta
08-16-2002, 10:22 PM
Hello I was wondering if anyone used the 3M 39006 before? I think it is a cleaner,wax,and fine scratch remover just would like to know if it is any good I own a black T/A and was thinking of usig it.I know that 3M products are pretty good any help would be appreciated
KevinSS
08-17-2002, 12:37 PM
That product is 3M One Step Fine cut wax, it contains alumium oxide as the abrasive, cleaner solvents, and carnauba wax. It will not last long at all on a black surface being carnauba wax. You will be better off using a straight polish compound like 3M Swirl Mark Remover part number 39009 and then as a second step using a synthetic wax or polish as a final coat. The ALL IN ONE waxes and polishes like the 39006 always produce limited results. Kinda like a a combinatation cleaner/conditioner product, how can you clean and condition at the same time?
You can see what is in the 39006 using this page: http://products.mmm.com/US/MSDS/msdsSearch.jhtml?_DARGS=%2FUS%2FMSDS%2FmsdsSearch. jhtml.2
and type in 39006 in the trade name box and hit go.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com (http://www.zainobros.com)
Remember #3
black97ta
08-17-2002, 06:31 PM
Thanks kevinSS if I use the 39009 what do you think I should use as a polish and or wax/sealant I heard a lot about zanio but don't want to spend a ton of money what would be your secod best choice. Thank you
Hookerf14
08-17-2002, 11:06 PM
Buy a small supply of Zaino and you will not go back. I was using McGuires Gold Class (very good) but went over to the Z side. I'm sold. And you said you have a black TA....
want it to look like a mirror...zzzzzzzzz
02 35th Annv LE conv M6 SLP 345hp, 96 Z28 conv A4
KevinSS
08-18-2002, 01:21 PM
<font face="Verdana, Arial" size="2">Originally posted by black97ta:
Thanks kevinSS if I use the 39009 what do you think I should use as a polish and or wax/sealant I heard a lot about zanio but don't want to spend a ton of money what would be your secod best choice. Thank you</font>
You do not have to spend a whole lot of money by any means, after you use the 39009, wash the car with Dawn and get some Z-1 for 8.95 and Z-5 for 16.95. The bottle of Z-1 will last you about 2 years (you only use the Z-1 oncer per 6 months) and the bottle of Z-5 can do 12 to 14 coats or more on one car.
96 Black Impala SS
Remember #3
