Opti's and timing sets
Old Jun 17, 2003 | 01:28 PM
CompAirflow's Avatar
I am switching over to a vented optispark system and when I started to reassemble, I noticed you have to change the actual timing set, (actually the camshaft sprocket gear) Has anybody ran into this before and if so did you have to buy a new set or can you just drill the old one out? If so what size hole do you drill?
Need help quick- Thanks for any replies
Old Jun 17, 2003 | 02:28 PM
Blk94Z28LT1's Avatar
if you change to the vented type you have to change timing cover, cam, vented opti vaccuum harness, a small intake manifold fitting, pcv hoses for a 95-97 f-body ( if you want to or get a small tee) . The cam has a longer dowel pin and a bigger hole in the front. I'm sure there maybe a few other things you need, do a search and find the list of GM part numbers you need
Old Jun 17, 2003 | 03:20 PM
anaik's Avatar
Here's a write-up on the swap.
http://para.noid.org/~muttvette/opti.html
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
Jlo
Feb 3, 2015 09:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
