StangEATR
06-16-2003, 06:12 PM
my 81 camaro has one of those scoops that look like a tear drop. There are slots facing the winshield that have metal on them like doors. They open and close by hand but theres nothing connected to it. I read somewhere online that it opens at full throttle but im not sure. Does anyone know about these?
talos
06-16-2003, 06:16 PM
ive heard thats there is like a motor for it or something, sorry im not sure... check at Nastyz28 (http://www.nastyz28.com) best 2nd gen site u will ever see :)
There's a solonoid that activates the flap.
The activation switch under the gas pedal might be bad, or the solonoid might be gone, or the wiring may have come disconnected. With a little troubleshooting you should be able to isolate the problem.
CoryM
06-16-2003, 09:37 PM
Ya there is just a solenoid (a magnet that moves a rod when electricity is applied) that is controlled by a wide open throttle (WOT) switch on the gas pedal. Both parts are fairly available from places such as Year One. I have both here but want to sell them with the scoop.
CoryM
StangEATR
06-16-2003, 10:29 PM
aright thanks but when does it supposed to open, on full throttle, or just whenever ur on the gas?
Dirt Reynolds
06-16-2003, 10:33 PM
Full throttle. As in pedal to metal. Heel to the steel. Boot into the radiator.
CoryM
Only supposed to open when your foot is on the floor, although you can adjust it wherever you like. You could use almost any push button "momentary on" switch for the pedal mounted one. I think they are fairly cheap to buy the correct one though.
CoryM
Yeah, the correct switch under the gas pedal costs something like $15 at a GM dealer. At least mine did around 8 years ago.
Ls1smlblck
06-18-2003, 01:33 PM
I have mine wired to a toggle switch. Flipp it on to have it open when the ign. is on or off to have work only when the pedal is to the floor.
