Procharger guys > Restictor in air line going to FMU?
Old Jun 15, 2003 | 08:25 AM
Kimchee & Rice's Avatar
Just a quick question for you Procharger guys >
I have been re-routing some vacumm lines under the hood in order to remove the AIR and fuel vapor purge system and make a better PCV system for my 95 Procharged TA.
I don't have the Procharger install instructions anymore, so I have a question.
There is a y-fitting that goes to the Procharger FMU. In that fitting is a small brass restictor.
Is the air restrictor in the vacumm line needed for the vacumm/boost signal that enters the FMU? I am not sure if this y-fitting even goes to the FMU per the Procharger instructions.
Thanks,
Ron
Old Jun 15, 2003 | 08:48 AM
1st and goal's Avatar
It's been a while since I ran the FMU but I don't recall a "Y" fitting being in the equation, unless you used it to splice into an existing vaccuum line. The restrictor goes just before the FMU.
Brady_96Z posted my instuction manual at www.turbocharged.net
Marc
Old Jun 15, 2003 | 09:05 AM
1st and goal ...
I looked at the web site you provided. Can't find the Procharger install intructions link anywhere in there
Ron,
95 Procharged TA
98 TA Heads, Cam, Headers car
Old Jun 15, 2003 | 12:38 PM
Sparkz28's Avatar
http://www.turbocharged.net/ati_instructions1/
http://www.turbocharged.net/ati_instructions2/
that should do it......
Old Jun 15, 2003 | 12:55 PM
Sparkz28 ....
Thanx much
Old Mar 5, 2005 | 09:29 PM
exgmguy's Avatar
Re: Procharger guys > Restictor in air line going to FMU?
Does anyone know about what diameter that restrictor is?
Old Mar 5, 2005 | 09:30 PM
exgmguy's Avatar
Mig sig is sooooo 1999....
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
Red97LT1
Aug 7, 2002 05:45 PM
