Will a 93 Intake Fit a 95
Old Jun 15, 2003 | 01:51 AM
AENIMA95z28's Avatar
I heard there was a difference in the 93 intake manifold, will it fit my 95, i found a ported intake with 58mm TB for 150.
Old Jun 15, 2003 | 02:04 AM
TTT
Old Jun 15, 2003 | 02:29 AM
Tofus 93Z28's Avatar
it will fit
but will it work....??? the fuel rail set up is different...could you make it work... possibly.... but not easily
Old Jun 15, 2003 | 09:09 AM
well i still have my fuel rail setup and injectors, if i used mine from my 95 would that fit the 93 or is it a different setup which has different mounts ?
Old Jun 15, 2003 | 11:10 AM
the rail actually seats differently on the intake itself..you will need the 93 fuel rail and the fuel inlet lines are prebent differently and the fpr is located differently also....
in all reality, no it wont fit is the correct answer... but then someone would try and prove me wrong and tell me how they did it........
Old Jun 15, 2003 | 11:40 AM
atljar's Avatar
Twin fuel crosovers on the rear of the 93s. Newer have a front and rear cross over. Fuel pressure regualtor is different, as is the way the fuel lines connect to the rail.
Old Jun 15, 2003 | 11:45 AM
funina91ss's Avatar
I have a 94-97 intake forsale its ported to 58MM and painted silver looks real nice I will sell it to you for a 150 shipped.I am emailing you pics
Old Jun 15, 2003 | 12:57 PM
that sounds like a great deal, send me pics please, how much would it cost for you to throw in a 58mm throttle body too?
Old Jun 15, 2003 | 03:25 PM
funina91ss's Avatar
I dont have a 58 mm tb just the intake only sorroy. I have a stock tb it you want it but you already have one of them. I couldnt send you pics so here are someintake pics The holley tb I already sold.
Old Jun 15, 2003 | 03:30 PM
wow so that silver one is it. Thats pretty cool, This Intakes port job was desinged for a 58mm throttle body correct. I am serioulsy interested in buying this from you ASAP, just a few more questions first. From what i hear your supposed to match the Intake port to the size of the throttle body, if this is correct i just need to know what size TB i should get. Finally is this unit just the core, or will it come with Fuel Rail, injectors, Vacuum Connections etc.
Old Jun 15, 2003 | 03:34 PM
funina91ss's Avatar
it is just the intake only. you will have to use your Fuel rails and inj. etc. etc. it is ported for a 58MM tB you can use the stock one or a 52MM or a 58MM Email me and I can take some better pics if you want.
Old Jun 15, 2003 | 03:35 PM
turbo_Z's Avatar
you can fit any size TB to an intake that will allow for a 58mm.. stock size is a 52mm bore and the stock tb is only 48mm.
Old Jun 15, 2003 | 03:37 PM
O last two questions, about how many miles have been through this intake and im correct to assume that there is not a thing wrong or damaged with it right?
Old Jun 15, 2003 | 03:38 PM
funina91ss's Avatar
The guy I got the intake from said it had 36k which really dont matter its a non wear item
Old Jun 15, 2003 | 03:39 PM
just sayin thanks to all those who are helpin with my questions.
