AmericanMuscle
06-14-2003, 06:17 AM
I have 2002 z28 with stock 2.73 i believe is a 2 series carrier. Is it possible to switch to a 3 series carrier??? I want to put 3.73 gears in.
Question on changing rearend gears??AmericanMuscle 06-14-2003, 06:17 AM I have 2002 z28 with stock 2.73 i believe is a 2 series carrier. Is it possible to switch to a 3 series carrier??? I want to put 3.73 gears in. SwingDriverZ28 06-14-2003, 03:42 PM Yes... thats all I know silversupersport 06-14-2003, 04:42 PM yup if you have 2.73's then you have to switch to a 3 series carrier. 3.73's in an auto, that should be fun. :D Freak 06-16-2003, 04:35 AM you CAN switch to a 3 series carrier, but you do not HAVE to. they make thicker 3 series gears for 2 series carriers, i know richmond makes them, but i dont know who else GoFast908Z 06-16-2003, 05:23 AM Originally posted by Freak you CAN switch to a 3 series carrier, but you do not HAVE to. they make thicker 3 series gears for 2 series carriers, i know richmond makes them, but i dont know who else are those thicker gears as reliable as changing the carrier? AL SS590 M6 06-16-2003, 05:48 AM Originally posted by GoFast908Z are those thicker gears as reliable as changing the carrier? Yep Got-LT1 06-18-2003, 01:04 AM I would just use the 3.73s for the 2-series carrier, a little cheaper and about the same strength.Originally posted by silversupersport 3.73's in an auto, that should be fun. :D It is VERY fun :D | ||
