Dawn - Clay - Dawn Right?
Sparky
06-07-2002, 07:22 AM
It's been awhile and I'm stripping down and starting over. You do a Dawn wash again after you clay, right?
After that wash, I can go straight to Z-1/Z-5, right???
Thanks guys!
Mark
JasPow
06-07-2002, 07:41 AM
Dishwashing detergent is BAD for your paint....nuff said. Meguiars has a cleaner that you use after you do a wash with a "car wash" soap.
1996 Pontiac Firebird Trans Am A4
w/ 3.23 gears and a few extra bolts.
Recently had a tranny rebuild done
w/ shift kit and 2800 stall convertor.
Hawk313
06-07-2002, 08:32 AM
That's what I would do.
DJCobol
06-07-2002, 08:50 AM
Dishsoap is not bad when used correctly. Use it when you want to cut all the crap off your finish before applying new stuff. If used on a regular basis, yes, it can be bad. But in this case, no.
Sparky, after you dawn wash and then clay, you can use whatever you want to for the second wash. There shouldnt be anything left for the dawn to cut through. So if you want, g'head and use dawn, or meguiars, or mothers, or zaino soap. The second wash doesnt matter.
Chris™ (http://www2.gvsu.edu/~stigersc)
<A HREF="http://www2.gvsu.edu/~stigersc/car.html" TARGET=_blank>'97 Cutty - "Pull Me Over" Red & "Gimme a ticket" Yellow
</A>
The Peter Potter Philanthropy Party Project posts perfect prose again!!
KevinSS
06-07-2002, 09:26 AM
<font face="Verdana, Arial" size="2">Originally posted by Sparky:
Thanks guys!
Mark</font>
Ok, everyone read this VERY closely, I have to answer this question 4 or 5 times per day on different boards. This is directly from Sal Zaino and is his offical word.
Dawn is only used ONCE and only ONCE BEFORE your first coat of Zaino EVER. Dawn has NO place in the Zaino system after that. The only reason Dawn is used as it is an excellent grease cutter and will remove whatever oils is present on the paint left over from previously used waxes (Zaino does not use an oil on the paint)
Dawn will NOT strip Zaino. If you want to clay the car, that is fine. Wash the car with Z-7 Show Car Wash, dry it, clay it, and re wash with Z-7 and dry again. Then you can proceed to re-apply your favorite flavor of Zaino.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com (http://www.zainobros.com)
Remember #3
[This message has been edited by KevinSS (edited June 07, 2002).]
DohHunter
06-07-2002, 09:34 AM
Dawn, Clay, Z7. Thats what I did.
Michael
2002 Sunset Orange Metallic WS6 Coupe
GMMG Exhaust, MTI Clear Lid, BMR STB
2002 GMC Sierra 1500 Sportside, 4.8 with 5spd
Street Scenes Grille,
HID Stage II Xenon Kit, Kenwood Speakers w/
12" Sub and Amp
Sparky
06-07-2002, 12:00 PM
http://web.camaross.com/bb/frown.gif sorry . . . .
I thought started from scratch I'd go back with Dawn - guess not!!
I'm curious, though, on a fresh start, wouldn't Dawn be better at cutting any crap off?
Mark
Kevin V 2002 SS
06-07-2002, 06:30 PM
If you already have Zaino on the car the Dawn will NOT remove the Zaino. If you are just starting with Zaino, then yes, use the Dawn to remove old wax and oils, before you clay.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth, Direct-Flo lid with Holley filter and Mallory polished MAF ends.
Louisville, KY
