Are these aluminum LCA's and panhard rod good for autoxing or drag racing?
Rob94hawk
06-12-2003, 11:53 PM
What do you think of these:
aluminum LCA's (http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItemWithCategory&item=2411711152)
aluminum panhard rod (http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItemWithCategory&item=2410722252)
thanx
1LEThumper
06-13-2003, 12:02 AM
http://www.jonaadland.com/Z28/Mods/LCA/AluminumLCAs.html
Read, learn, and smile :D
94bird
06-13-2003, 05:14 PM
The fact that they're aluminum is not a problem, but I don't know anyone using the ones you're looking at. I have heard before that Slotcar uses cheap rod ends, and at that price I'm guessing that's correct.
Larnach
06-13-2003, 08:50 PM
They are making a ton on those control arms if they are using those cheapo rod ends... I plan on using QA1 rod ends and maybe marketing them... shoot a royalty or something off to that guy in Washington who inspired me to do it too.
Wonder if he surfs this board?
Jon A
06-13-2003, 09:20 PM
Thank you very much. That'll be $20 a set.
Just kidding! :D
Larnach
06-13-2003, 09:22 PM
Seriously though man... PM me, I think even though I'm not legally required to do it;) Maybe we can work something out as it was your idea that sparked mine.
2002Z28SSConv
06-13-2003, 10:34 PM
I use the equivalent PHB from DMS. I think it helped out with quick transitions from side to side. It used to be very easy to lose the rear if you didn't pausein the middle when going side to side in fast turns. Slaloms are more controled too. But the springs, 35mm front sway bar and VictoRacers are part of that equation too. I'm still on the stock control arms though. Just having the PHB makes enough noise. I think with control arms too it would be annoying to drive on the street much. I do all right at the autocross. This year I haven't lost in GTP (FP for most of you). When I start getting beat again, maybe I'll think about gearing more toward a racier suspension. 'Jeff94TA' and 'JimMueller' have a bit of catching up to do first.
But yeah, good for autoX. I would think that the solid ends might hurt at the drag strip though. The solid arms would help though.
Jon A
06-14-2003, 05:51 AM
Really, don’t worry about it. People have been making control arms like that since before I was born. It’s nothing I invented. All I’ve done is expose the “buy a pretty powdercoated part on the internet generation” to a relatively simple process. But since many of the above are unwilling to screw a rod end into a tube, you probably can make some money doing it for them. If so, you are doing them a service by keeping them from buying crap and you deserve a bit of profit for your labor. Kudos to you if you do.
On the Slot Car Racing arms:
1) Given the range of adjustment listed on their website their arms are shorter than I would prefer. When adjusted to the proper length you won’t have much thread engagement which will make them weaker. Probably still strong enough but you’re eating into the margin of safety.
2) They don’t list the diameter or wall thickness of the tubing. It’s probably the same as I use but I’d want to make sure before I put them on my car.
3) On the first set I made, I found having wrench flats on only one end was enough of a PITA when tightening the jam nuts. Having no wrench flats must really suck. Those knurls sure look knarly, but they’re useless.
4) At that price, they’re selling them with cheap-ass-crap rod ends unless they’re selling them at a loss out of the goodness of their hearts.
If your PHB is relatively new and makes enough noise for you to even notice it, it's because of the cheap-ass-crap rod ends referenced above.
chuck
06-14-2003, 07:34 AM
My LG aluminum LCA's and PHB with aluminum QA1 rod ends are still quiet after 11K miles and a lot of racing. I bought them before the "cheap" way was exposed :mad:
Jeff94TA
06-14-2003, 09:00 PM
Second place to you this month my friend. Let me get used to the new Victoracers and one of these months that little ole SS will be mine. :D
2002Z28SSConv
06-14-2003, 10:43 PM
:bow: I'll deliver the trophy to you myself.
Of course then I'll have to buy Hoosiers. :p
Jeff94TA
06-14-2003, 11:06 PM
Don't Hoosiers put you in GTR? That would be fine since I wouldn't have to compete against you any more. :D All joking aside I know I will probably will never own that SS but it won't keep me from trying. :bow:
Rob94hawk
07-06-2003, 02:33 PM
Excellent! thanx!
Now what's the length of the tubing that I need for the panhard rod??
1LEThumper
07-06-2003, 05:46 PM
Uhm....
http://home.earthlink.net/%7Ejonaa/AluminumPHB.html
Jon A
03-07-2004, 07:09 PM
It has been brought to my attention that you can no longer get the 1" by .250 wall tubing from which to make the spacers from Aircraft Spruce unless you want to buy 6 feet of the stuff. :eek: There goes that plan for making cheap spacers..... :(
I've looked into getting some stepped aluminum spacers machined like this:
http://www.jonaadland.com/NewPics3/SpacerLCA.JPG
Depending upon how many people were interested, they'd go for around $30 for a set of 8 for the LCA's. Would you guys be interested in having me do this?
93formula
03-14-2004, 11:26 PM
i know i would
bruecksteve
03-15-2004, 02:45 PM
You're going to be a busy person Jon!!!!
93formula
03-15-2004, 09:35 PM
i got a question about the life of these though, do they suffer from fatigue? my car is daily driven.
brain
03-27-2004, 05:34 PM
Were you ever able to get those spacers made? If so, I'll take a set. If not, put me on the list for when you do! One thing, you should make it a set of 12 so you can do the PHB as well as the Control arms.
Jon A
03-28-2004, 10:35 PM
It doesn't look like I need to. Others have found that part # MB1 here:
http://www.stockcarproducts.com/susp3.htm
Fits the LCA's. Keep in mind the LCA's and PHB take different sizes (that's why you wouldn't want 12 of the same). For the PHB the cheapest way is to us the 1/2" spacers and rod end reducers as suggested on my page. Or, one could cut the MB1's to fit.
93formula, their fatigue life should approach infinity with normal use. But at $12 each, one can time them out every couple of years and only be out less than the cost of one rod end.
93formula
03-29-2004, 02:41 AM
would you be building these? when are you taking orders?
Jon A
04-01-2004, 03:52 AM
No. The idea was to provide others with the information they need to make their own. I don't have enough time to work on my own car as much as I'd like, much less make stuff for other people. All the info is there, it's not that difficult.... ;)
93formula
04-01-2004, 10:42 PM
sorry it just takes so long between responses on here i must have gotten mixed up.
