Door coming apart...
Old Jun 12, 2003 | 11:59 AM
Hawaii93z28's Avatar
Exclamation Door coming apart...
I'm not sure if anyone else has had this problem, but I hope you guys have some suggestions...
The outer fiberglass door panel on my 93 has begun to separate from the inner assembly. I'm assuming it's from years of opening and closing the door. There is a seam you can see when looking at the door jamb. It's causing a bunch of problems such as window rattle and poor weather strip sealing.
I tried to JB Weld it, but it didn't hold. Does anyone have any suggestions?
Thanks in advance.
Old Jun 12, 2003 | 12:44 PM
Kris93/95Z28's Avatar
I had to have the door skin replaced on the 93 in the sig. About a year later I was having the same problem as you ,and I took it back to the shop that did the work and they replaced it for free and used a type of glue from 3M. I would check and see if a local body shop can recommend a good glue to use, since I figure they would have seen this before had they fixed a 93+ F-Body
sscott
Jan 17, 2015 04:30 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
