Removing Motor mounts?
Old Jun 11, 2003 | 07:30 PM
thewinner's Avatar
In order to remove the bushing, do i need to drill/chisel the rivets out?
Basically Im buying some poly mounts and need to remove the stock ones, and will the new ones come with the hardware to replace those rivets?
Old Jun 11, 2003 | 08:31 PM
Soma07's Avatar
Yes, you'll need to drill out the spot welds that hold them together. The kit should come with some zipties which will hold the pieces together until you bolt them down.
Old Jun 12, 2003 | 05:38 PM
thewinner's Avatar
well, i was only looking at the drivers side mount when i posted this. how do you go about removing the passenger side? it doesnt have any welds?
Old Jun 14, 2003 | 05:31 PM
thewinner's Avatar
ttt for the passenger one.
Old Jun 15, 2003 | 12:12 AM
Soma07's Avatar
Same proccedure, drill out the spot welds and replace the rubber part in the middle.
Old Jun 15, 2003 | 01:28 AM
thewinner's Avatar
i didnt see any welds on the pass sdie, looked like it was pressed together! guess ill look in the morning
HectorM52
Jul 30, 2017 11:46 AM
rjc1629
Jan 27, 2015 10:46 AM
mattszm6
Dec 14, 2014 07:09 AM
