Help me I cant get my wheels off!!
I went to rotate the tires and like 5 of my lug nuts are stripped!! I cant get the d*mned things off. Its really Pissin me off. Any ideas how I can get these off? I'd like to try it before I take it to someone who can break em off. Thanks much!
Mike
Mike
Tried the vice grips....Nothing. (I know left is loose)
But as far as stripping them.....these lug nuts are sh!tty!!! I think ones made out of aluminum foil would be better. But they damn sure are on there tight since I snapped 2 tools in half already from the pressure. After awhile I tried a breaker bar and nothing. Just a broke 1/2" to 3/8" adapter.
maybe someone else will like to chime in or disagree w/me, but it's just a thought. Have you tried adding a little heat? You may even be able to get a regular four way lug wrench, if you can find one that will fit and if your lugs aren't too far gone, add some heat via propane torch, put on the four way, six or seven foot pipe section on top of that and go at it. Just a couple thoughts. Hope this helps a little. ---J.Bird
Originally posted by jbird
Yep, sounds like a good idea. You know what they say, when all else fails, get a bigger freakin' hammer. lol
I havent ever taken the wheels off. I wouldnt have tightened em so much. Whoever the owner was before me either was retarded or brought it to a retard. I should just ****** up a torque wrench here from work. Damn things are expensive.
A while ago I had the same problem when I tried to put on my 17"s. The old lugnuts were rounded off, the 19mm socket was rotating on the nut and I was very hopeless.
Took car to the tire shop, and here's what they did: A gorilla like fella took two fuggin big hammers and started to beat the s** out of the lugnuts. After that he took the same 19mm socket with an impact wrench, and it came right off. By beating the lugnuts you basically "repair" the hexagon on the nut.
My buddies car had rounded off lugs when he bought it and we had to beat a smaller socket on the rounded off lugs. It took a lot of beating and screaming but we managed to get all of the messed up lugs off withough breaking anything.
