Alignment numbers- What are you running?
bad1LEz
06-10-2003, 02:40 PM
I am going to get another alignment, and I have some numbers that I got off of this site, along with my own ideas. I was curious what caster/camber, ect you guys are currently running? I do not go to the strip. I like tight curvey back roads, as this is the direction I am taking the mods with this car. When I grow some bigger nuts I plan on hitting a road coarse or two.
chuck
06-11-2003, 12:40 AM
The generic answer is max negative camber, then max positive caster, and 0 toe. but this varies by car. I am running -1.7º camber, +4.5º caster and 0 toe. This works pretty well on the street and track.
Next time I have it aligned, I am going with 5º caster, and a little toe out. This is for autox, and is not a daily driver.
Rickm
06-11-2003, 01:05 AM
I agree with what Chuck said. I'd Like to add It's hard to get allot of negative camber on a non-lowered car.
I'm running -.6 Camber, +4.8 caster and 0.0 toe in.
