how hard to install bilsteins??
1.8ttolt1
06-09-2003, 07:33 PM
how hard is it to install bilsteins, front and back, also is there an install guide somewhere for fourth gens (94)? thanks very much for the help
KeithO
06-09-2003, 07:53 PM
Rears are a snap on any f-body.
I did the fronts on my 3rd gen with no problem.
I tried to do the fronts on my LS1 earlier in the year and screwed it up. I took it to a garage to get it done right.
On your LT1, are the shocks inside the spring? If so, and you don't like being pissed off, take it to a garage. If the front suspension is like my old 3rd gen, do it yourself. It's not too bad.
RobK
06-09-2003, 09:22 PM
Rears aren't too bad, unless you have a convertible :)
Not nearly as bad as the front, however. Perceived difficulty depends upon your patience, the quality of the spring compressor you are using, & if you have airtools. I won't be doing this again without air tools :)
The hardest part for me was definiately compressing the spring compressor with hand tools. Next to that was trying to undo the top nut--thank god for my sawzall to take car of that rusted nut! :)
BTW, if you are going to do this yourself, don't forget to put a blob of greese at the top of the new one.
Rickm
06-11-2003, 12:57 AM
Just installed my springs and shocks last week. I agree the air compressor and Air ratchet made quick work of compressing the front spring.
LS1 How to (http://www.ls1howto.com)
