Is ZFX necessary? Can I get the same results just using Z- 1and Z-2?
davey
04-15-2002, 09:47 AM
I don't know if I want to fool around with the mixing in the ZFX. Can I just stick with Z1 and Z2 for optimal results?
MikeLS
04-15-2002, 10:25 AM
I used Z1 for a couple years with the polishes before ZFX came out. You'll still get great results using Z1+Z2 or Z5. Z1 is only used twice a year or every 10 coats of polish though. The benefits of ZFX make Z1 sort of obsolete. ZFX allows 3 coats per day versus 1 with normal Z2/Z5. ZFX dries much quicker, adds durability, and makes the polishes easier to work with i.e. spreading and buffing. And, you can use ZFX on every single coat of polish. So, for the BEST results, I'd use ZFX but you can still easily use Zaino with Z1 if you like, the way many of us used Zaino for a long time.
http://web.camaross.com/bb/wink.gif
*Mike's 1992 Camaro RS 25th Anniv.* (http://mls77.homestead.com/92camarors.html)
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
Shine by ZAINO! - Special Thanks to Sal Z!
davey
04-15-2002, 10:39 AM
So if I use Z-2 and ZFX together...how many minutes do I have to wait to do it again? http://web.camaross.com/bb/smile.gif
Also, ZFX can't be used by itself, right?
MikeLS
04-15-2002, 10:49 AM
With a mixture of ZFX/Z2, it should dry in 15 to 30 minutes depending on the temp. After you buff it off, you can immediately apply another coat, wait and buff again, then apply the final third coat for the day. Without ZFX you can only do 1 coat per day. It's up to you...
ZFX is in a 2ml vial and must be mixed with the polishes. There's no way it could be used by itself... ZFX Vial (http://autopia-carport.com/forum/attachment.php?s=42c06d1b66984d722f4be1eadb388184&postid=85211)
