Major Problem Need Help (is it a mis??)
Old Jun 6, 2003 | 09:30 AM
Dmx4ever3's Avatar
Hello to everyone one on the board
OK let me get started on telling you my problem(s) :
i think i may have a MIS but IM not sure i just got my wires and plugs done when i did my headers but the wires burn like 3-4 times till my shop moved the one wire by the valve cover then it was OK
when i sit in the car and give it gas around 1900 2800 rpm the car has a shake to it and it doesn't feel healthy at all, the shop says it can be an injector or a MIS he says that there is something wrong also but not sure could be like 4 things he's says i can be running rich or something also my cutout is always open do to the MPP2 motor broke and IM waiting for my new one in the mail but when i drive the car it hesitates and is not smooth running also i got my clutch installed DF CENTERFORCE and put RP transmission fluids in it call scyromax or something and also got my 4.10s put in at that time. i have kinda a problem with shifting in reverse like i have to force it into it and when IM driving in some gears the car bobs back and fourth when you shift or i just go to give it gas and it does it, and on top of all this i get 150 to a tank of gas please help me with my flaws in my car make it all better and tell me what i should do
Old Jun 6, 2003 | 07:40 PM
Dmx4ever3's Avatar
ttt
Old Jun 7, 2003 | 08:52 AM
Dmx4ever3's Avatar
ttt
Old Jun 7, 2003 | 11:29 AM
94FlamdS10Blazr's Avatar
have you pulled your plugs yet to see how they look?
Old Jun 7, 2003 | 11:55 AM
Shankels94TA's Avatar
So you still have wires on there that have been burnt?
Old Jun 8, 2003 | 03:05 AM
Dmx4ever3's Avatar
Question
just had the new plugs put in few months ago like maybe 2-3 and the wires are new wires msd 8.5mm and when it burn a new one was put in its place and the optispark was replaced about 15000 miles ago
Old Jun 8, 2003 | 04:27 AM
96redformula7's Avatar
I would check, double check, and triple check that your wires are all going to the rirght cylinders. I would bet money that you have two or maybe more wires in the wrong locations.
Old Jun 8, 2003 | 05:20 AM
Dmx4ever3's Avatar
Can this hurt my car and make the life of the engine not last as long and when i got the gears put in is when i can feel the problem more in the rpm range
Old Jun 9, 2003 | 03:21 AM
Dmx4ever3's Avatar
TTT
Old Jun 9, 2003 | 08:31 AM
bustamove's Avatar
I would also check your plugs. Had a problem like that and one of my plugs had a crack in it.
ad356
Apr 11, 2015 11:12 PM
karnykamaro
Feb 2, 2015 01:37 PM
Jazsun
Dec 29, 2014 12:14 PM
