Artfrombama
06-05-2003, 11:27 PM
A buddy recently went from a turbo 350 to a new Super T-10, new Hurst shifter, new blowproof, new flywheel, new Ram Borg&Beck clutch setup.
Transmission is REALLY STIFF! Forget speed shifting, transmission is really "notchy"... As if the interlocks won't allow smooth "butter smooth" shifting... Hurst shifter is adjusted perfectly, that's not the problem.
Is this a charicteristic of the newer Super T-10's? If so, what do we do to get the thing shifting smooth???
Another unrelated(?) problem, when the clutch is set for the 1" free travel at the top of the pedal, the clutch will not fully disengage when the pedal is fully depressed.
When the clutch is adjusted to release cleanly and you can "find em' instead of grind em" the throwout bearing is aganst the pressure plate fingers.... NO free pedal play..
Mismatch of parts????
Any and all responses appreciated!
