Dude with EGR block of plates!!
Old Jun 4, 2003 | 01:28 AM
NiteRider's Avatar
Hey man, or who ever knows hes site, shoot it my way, I forgot it.
Old Jun 4, 2003 | 01:55 AM
Skull Leader's Avatar
Lightbulb
Go to Home Depot and get some sheet metal for about $3.00, trace an outline and make it yourself. Anymore than that, and I'll sell you a chrome oil filter cover for $20.00.
Old Jun 4, 2003 | 01:57 AM
NiteRider's Avatar
Listen man, I don't need your mombo jumbo, I bought those plates from the dude on here and i'd recommend them to everyone.
I know they can be made but the fact is he made nice ones, thick, and well cut for a cheap cheap price.
Old Jun 4, 2003 | 04:50 AM
1QUIKTA's Avatar
http://www.mycamaroz28.homestead.com/
Steve will fix you up.
Old Jun 4, 2003 | 04:58 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
what IS the point of blocking the egr if it ain't open at WOT then its not hurting performance....????
Old Jun 4, 2003 | 09:01 AM
Eddie95Z28's Avatar
I suppose for a neater engine bay? I know it is all in the back... Hmm... better question is. What do you use to block off the side on the header/manifold ?
Old Jun 4, 2003 | 11:00 AM
4DRSS's Avatar
A complete set is also available from Clear Image Automotive http://www.clearimageautomotive.com/...-off%20kit.jpg
Old Jun 4, 2003 | 11:45 AM
ledfootz28's Avatar
yo niterider which ones do you check on the order form??i have no clue how many plates i need and theres 3 things to chose from:2 plates(intake manifold kit)2 plates(egr tube kit)and 3 plates(intake and header kit).mite be a stupid question but help is appreciated.
Old Jun 4, 2003 | 12:19 PM
TimbrSS's Avatar
there's 2 holes on the back of the intake manifold, 1 for the egr valve, and 1 for the tube that goes to the header. If your header has a EGR fitting, you will need all 3 peices if you plan on removing the egr valve. If the header does not have EGR fitting, you only need the 2 for the intake.
Old Jun 4, 2003 | 06:29 PM
NiteRider's Avatar
Because it may still leak one day.. Why risk it?
Old Jun 5, 2003 | 02:01 AM
Eddie95Z28's Avatar
Does the manifold plate seal well to a mac header? I can't believe GM would make this connection only one bolt. I should have just had the mac side welded shut... I can't get it to stop leaking!!!
Old Jun 5, 2003 | 04:12 AM
revtime's Avatar
I have read that the pipe fitting (the one that goes from the manifold to the exhaust manifold) IS blocked off once you block off the EGR valve hole it feeds the EGR so once blocked off it is basically blocked off too.
Is this true? I need this settled once and for all.
Old Jun 5, 2003 | 04:43 AM
frmula1's Avatar
is the car still emissions legal without egr???
Old Jun 5, 2003 | 05:00 AM
revtime's Avatar
No.
Old Jun 5, 2003 | 10:55 AM
ledfootz28's Avatar
revtime,you sure its not emissions legal?i thought getting rid fo the egr and air will still alow you to pass emissions?
