hot936spd
06-02-2003, 07:19 AM
i have a 67 camaro, and im replacing the front drum brakes to disc brakes, and I purchased, spindels, and disc brakes off a 71 monte carlo. What all do i have to do to make that work thanks,
Please email me at
Mustanggobbler@aol.com
CHPshown67
06-02-2003, 01:56 PM
the complicated part of the disc conversion from a non-camaro donor is matching brake line fitting sizes to calipers and the master cylinder. I bought a pipe flaring kit and match the right sizes to the lines, and flared them on. You also need to figure out what master cylinder you need with the right pushrod length. You obviously cant use the old drum camaro brakes, and if you got all the components from the monte carlo, that probably will work, but i dont know for sure. The 69 chevelle master cylinder and boost unit worked perfectly on my 67 camaro.
