kenken
01-30-2002, 06:48 PM
i just took off my headlight covers on my 95 and i have mad water spots on the surface right in front of my headlights. its painted black and its also plastic so how can i get rid of these spots.
thanks
ken
thanks
ken
water spotskenken 01-30-2002, 06:48 PM i just took off my headlight covers on my 95 and i have mad water spots on the surface right in front of my headlights. its painted black and its also plastic so how can i get rid of these spots. thanks ken MikeLS 01-30-2002, 07:42 PM Try distilled vinegar. Blot it on the spots, let it soak in for a minute or two, then wipe off. But, don't let the vinegar dry on the surface. Or, try a claybar (Mother's/Claymagic) or paint cleaner, like Meguiar's or 3M. ------------------ *Mike's 1992 Camaro RS 25th Anniv.* (http://mls77.homestead.com/92camarors.html) Dark Red Metallic (ext.) / Flame Red (int.) Flowmaster Crossflow, K&N JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers 20% 3M Panther Black Tint ZAINO! - Perfect Shine in Less Time! My Guitars, Metallica Style! (http://mls1.homestead.com/espguitar.html) kenken 01-30-2002, 09:17 PM i have the zaino claybar and nothing. water spot still there. maybe i try the vinegar. thanks ThePolisher 01-30-2002, 10:56 PM This is alittle info that Sal put out. Hope it Helps Most 'fresh' mineral deposits (water spotting, acid rain, etc.) can be removed using household white vinegar full strength. This is acetic acid and will loosen and remove the mineral deposits and not harm the paint surface. Most of the time, the water spot etching you see is simply the hardened mineral deposit, giving the illusion of etching into the paint. Believe me, when these mineral deposits harden. They become really tough and hard to remove. The trick is to not give them a chance to harden. If the above fails, then use a Clay Bar to remove them.... If those water spots on your car have been there for a while. They might be already etched into the clear coat. If Clay Bar will not remove them. Then what you are seeing is an etched spot in the paint surface, similar to acid rain mark etching.. Although, I am totally against using an abrasive product on todays clear coated finishes. It's possible in your specific situation, you might not have a choice. I would try 3M Foam Polishing Pad Glaze Swirl Mark Remover part #39009 by hand, not by machine, using very light pressure. This should do the trick. Be careful when doing this and only do the water spot areas, as the 3M is abrasive and will remove paint material. Don't forget to reapply your favorite wax or polish as the 3M product will remove any polish/wax. If you opt to go with the 3M Foam Polishing Pad Glaze... see following tips... 3M Foam Polishing Pad Glaze use By hand: Simply apply a small amount (about the size of a quarter) to a cotton diaper or piece of cotton towel and rub back and forth into about a 1' X 1' section using light to medium pressure until it starts to dry out. Then take a second towel and lightly rub back and forth until the polish residue disappears and the gloss comes up. If there are still some swirls visible you can repeat this step until they are minimal. I prefer using a less aggressive product a couple times instead of using a more aggressive product once. After you are done you can wash and apply your favorite polsih/wax.. ------------------ ***Authorized Zaino Bros' Show car Polish distributor*** george13@adelphia.net kenken 01-31-2002, 02:11 AM i have already tried with the zaino claybar but that didnt work. so i will try with the vinegar and if that does not help i will try the 3m stuff. can i get this 3m stuff anywhere or do i have to order the product. if that is the case can you tell me where and how to order. thanks ken ThePolisher 01-31-2002, 09:29 PM I purchased mine though the web www.3m.com (http://www.3m.com) ------------------ ***Authorized Zaino Bros' Show car Polish distributor*** george13@adelphia.net *SoRRy OfFiCeR* 02-03-2002, 07:07 PM did that paragraph say that sal zaino is against abrasives? doesn't he stand by the swirl remover..390009? or is that reccommendation made by someone else? thast an abrasive and i have used it on my green camaro adn have seen some great results...i noticed no damage to my clearcoat.not that i could see with my naked eye..... SO IS 3M SWIRL REMOVER 390009 BAD???????? KevinSS 02-03-2002, 09:25 PM <font face="Verdana, Arial" size="2">Originally posted by *SoRRy OfFiCeR*: did that paragraph say that sal zaino is against abrasives? doesn't he stand by the swirl remover..390009? or is that reccommendation made by someone else? thast an abrasive and i have used it on my green camaro adn have seen some great results...i noticed no damage to my clearcoat.not that i could see with my naked eye..... SO IS 3M SWIRL REMOVER 390009 BAD????????</font> Sal Zaino wrote the article I posted above, better re read it, look here: "Although, I am totally against using an abrasive product on todays clear coated finishes. It's possible in your specific situation, you might not have a choice. I would try 3M Foam Polishing Pad Glaze Swirl Mark Remover part #39009" If all else fails Sal is saying some times you have to use a mild abrasive. ------------------ 96 Black Impala SS Authorized Zaino Showcar Polish Distributor www.zainobros.com (http://www.zainobros.com) Remember #3 *SoRRy OfFiCeR* 02-03-2002, 10:02 PM thanks Kev....i must have been watchin the patriots beat the Sh*t out of the rams..... | ||
