02WS6
06-01-2003, 06:37 PM
Do any of the 17x11 ZR-1 rims come in any other offset besides 50mm and 36.5mm? I know the front 17x9's come in 56mm and 38mm, and I'm going to go with the 56mm's for the fronts. I was just wondering if maybe there is a 55mm or matching 56mm offset rim for the rears? I think the rims would look a little more flush with these offsets.:confused:
thanks
Bone Maro
06-01-2003, 07:59 PM
You will not find a genuine GM 17x11 rim that will fit a 4th gen F-Body. The closest bet is going with an aftermarket company like AFS (http://www.afswheels.com) that make ZR1 17x11 replicas, and with the correct offset for our vehicles.
What size tire do you plan on running on the 17X11" ? If your planning on running a 315 tire I suggest going with the 36mm offset. Everywhere I look people with 4thgens that ARE NOT lowered have no problems with rubbing with the 36mm offset. If your car is lowered go with the fbody offset (56mm?).
Ken S
06-02-2003, 02:19 PM
Search the autox/rr forum. there's been alot of talk about this subject..
