Line Lock ???
96Z28man
06-01-2003, 03:19 PM
how difficult to install?
ALso, do they void any kind of warranty??
Can they cause any sort of damage???
V6toZ28
06-02-2003, 12:51 AM
Not really ... you can get a complete kit from Thunder or TBryne for around $200, with everything you'll need and then some ...
... or you can get a Biondi solenoid and wiring kit from Summit for just under $50 and you'll still have parts left over. The only thing the Biondi doesn't supply - that you need - is the prebent brake lines. If you mount the solenoid in the right spot you only need one. Then take a coat hanger bend it into the shape you need for the other one as a template. Take to any brake shop and they will make it for you with the fittings for less than $10 ...
Dealer can make a case for you tampering with the brake system and void any brake work under warranty. Also a line lock is a fairly legitimate indicator of racing/abuse - read your warranty as to the specifics relative to racing ...
Not in and of itself ... but you will tend to to go (http://www.mysticz28.com/pics/burnout1a.jpg) through (http://www.norcal-ls1.com/multimedia/data/3026/1462dscn0454.jpg) tires (http://www.mysticz28.com/gtg/hrcburn1.jpg) rather quickly (http://www.mysticz28.com/gtg/hrcburn2.jpg) ...
Good Luck
96Z28man
06-02-2003, 02:56 PM
tks man
