Ferocity02
06-01-2003, 02:36 AM
I finally got all of them in and took it for a ride. In my opinion, the car is faster. I don't know if I'm just imaining it, but I think it is;). I got the Taylor "409" wires, which are identical to the Thundervolts, 10.4mm. They were a challenge to get in. Had to get under the car to get to one on the #8 cylinder.
At mid-upper RPM's it seems to pull harder, like it does at lower RPM's. I love it!!! Maybe one of my old ones was bad??? Whatever it was, I'm very happy, even though I drove my car off the ramps and spent hours fixing stuff:rolleyes:
KungFu
06-01-2003, 03:43 PM
K/A dood! I put the same wires on my car. Unfortunately I only have 6 out 8 done. :( need to get the rest done soon. Did you change the plugs? If so, to what?
Weird thing for me is that I noticed a downgrade in my gas mileage. Don't know if it has something to do with the 2 remaining plugs that haven't been changed. :(
fbird95
06-01-2003, 05:20 PM
Ferocity02 do you run these wires on a stock ignition set up? just wondering.
Ferocity02
06-01-2003, 09:25 PM
As far as I know the ignition is fully stock, except for the plug wires of course. How do I know if my plugs are new. By the way, I did not change them. I saw some text of the side of the plugs when installing them. Not sure it that means anything
fbird95
06-01-2003, 11:26 PM
i just wondered because those are some beefy wires you got there. I thought about geting a set, nut ever since the bosche platinm incident i just use stock replacements.
Ferocity02
06-02-2003, 12:25 AM
As far as I know, there isn't any modifications that can be done to the ignition, except plugs and wires. I don't think there are any replacement coils but I don't know.
i will probably do the plugs if I do another major install like headers, cam, or heads.
TerrorDome
06-02-2003, 04:11 AM
that's awesome!
as for me, my MSD wires and NGK's didn't seem to add anything.
seemed to make the idle smoother, but that's all
