intake manifold passages
Old May 31, 2003 | 10:22 AM
ryaskovic's Avatar
Question intake manifold passages
On the inside of the intake manifold, right behind the throttle openings, there are two holes in the floor of the manifold. Brent Franker talks about plugging these with earplugs when he ported his IM to 58mm. Does anyone know where these passages lead? From looking at it, I suspect it's where the EGR gases are allowed into the intake plenum, but I'm not sure. Anyone know?
Rob
95Z28
Old May 31, 2003 | 10:45 AM
SWINGRRR's Avatar
Im guessing that one is the EGR and the other is for the IAC. Just a guess though.
Old May 31, 2003 | 11:21 AM
ryaskovic's Avatar
Thanks for the reply. I'm pretty sure it's not the IAC....the IAC hole is on the same plane as the throttle openings.... between and below the throttle openings, and it's a seperate passage. The two I'm talking about are in the manifolds interior, behind the throttle openings.
Old May 31, 2003 | 11:42 AM
SWINGRRR's Avatar
OOOO, I get you now. I'll see what I can find for you.
Old May 31, 2003 | 11:43 AM
NOMAD's Avatar
Cool
I think it's EGR and MAP... Don't quote me on that though... Just tape over em and grind away Thats what i'm doing right now on an airfoil
EDIT< I think MAP is on top...
-Shannon
Old May 31, 2003 | 07:46 PM
ryaskovic's Avatar
-Shannon
Hey, quit putzing around on the computer and get back to work
You're right, the MAP is at the top. I've got my compressor charged up now (couldn't run it earlier 'cuz the kids were sleeping) so I'll be able to very what goes where. Pretty sure it's the EGR.
Rob
95Z28
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
